depends on offset, and tyre width aswell.
i have 17x9" rear, 17x8" front
the fronts sit in the guard a little bit with 235's on them
and the rears sat perfectly in the guards with 255's, but get a tiny bit of scraping on the guards with the current 275's on them.
https://www.sau.com.au/forums/topic/164327-rims/#findComment-3047192
20 x 8.5" front and rear with 225/30 tyres fit a R33 without any guard mods.
I have a set, will sell em to ya for $1800
[Michael] can you camber adjust a R33 at the front?
max camber I've gotten from the front is -2.5; im not sure if you can get anymore with the stock suspension arms
https://www.sau.com.au/forums/topic/164327-rims/#findComment-3049087
how did u adjust the camber? i cant seem to find anything to adjust it as it seems you cant get adjustable camber tops for whales.
yeap no camber tops for r33 :O you need upper or lower control arms (i cant remember which one lol)
not sure how it is done, i just go to the wheel alignment people give me 2.5 camber and they do it LOL! i think if i remember right it has soemthing to do with the bushes :P
https://www.sau.com.au/forums/topic/164327-rims/#findComment-3049473
these rims will fit... i have the same size wheels on my car and its on the floor!!! i have the rear guard sitting on the rim and have no clearance problems. i do however have problems chewing tyres out but thats all part of having such a low car. when your car is this low then u wheel align the rear the tyres straight again, it will rub!
https://www.sau.com.au/forums/topic/164327-rims/#findComment-3054274
tempe tyres said that they will be fine as long as it is 19-8 on the front and 19-9.5 on the back hopefully
....... always say that, might need spacer on front cos of caliper, unless u ordered a custom offset or they got it right. Dont need to roll the guards if u get falkens, otherwise yes! or u will shave your tyre (front) when taking humps at an angle (assuming you are lowering it)
https://www.sau.com.au/forums/topic/164327-rims/#findComment-3056248
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
