Guest Joeyz
Hi all!
Just thought i'd inform you that next months Unique Car's Mag will have a 5 PAGE write up on the only Z-TUNE in Australia.
They are all hand built and made to order!
Only 20 ever were made. Very good read!
I was able to get my hands on one through work.
Maybe one day.............................................................................
! :laughing-smiley-014:
https://www.sau.com.au/forums/topic/164363-unique-cars-mag/
Yeah, the Z-Tune is the greatest factory Skyline ever! Even better than the Nur version.
I remember reading that because when the made the Z they weren't building R34s any more, NISMO went and bought the cars from the public. It took a long time cause they would only accept the very best, low k's, no damage examples. After they got them they were fully stripped and rebuilt. I remeber they have SPAX suspension worth like $4000 per corner.
Would love to see one in the metal.
Edited by PhilTacular
https://www.sau.com.au/forums/topic/164363-unique-cars-mag/#findComment-3047526
