Hi,
I have wired up my safc2 to my r33 gtst though I am having some issues with woring up of the knock.
I know the purple wire on the safc2 is for knock but you have 2 knock wires on the ecu harness.
- Is there a second wire for knock from the safc2?
- I have the manual plus a d.i.y from this forum which is for a safc1 on rb20 and I am finding it all confusing. The rest is wired in okay.
- Can somebody please give me a step by step guide on how to do this.
Acutally I should of done a D.I.Y for an s2 r33gtst manual for safc2. I believe the wires from s1 r33gtst and rb20gtst are thr same colors but the s2 r33gtst ecu seems to have a few different color wires. There is also a different diagram for the 95s2 onwards. i
Thank you in Advance
Daniel
https://www.sau.com.au/forums/topic/164519-wiring-knock-for-a-safc2-on-an-r33/
Please any ideas, I need to get this sorted as its suppose to go in for a tune tommorow, though I will have to postpone it.
I have completed a search but have not come up with what I require.
Cheers Daniel
You have to temporarily connect to knock sensor 1, take reading, connect to knock sensor 2, take a reading and then connect permanently to the one with the higher reading.
It is in the installation manual :P
Edited by so_tred
Yeah, just use 1 wire.
I didn't want to cut both so just connected the wire that watched the rear 3 pistons (forgotton how i found out) as they are the hottest due to air circulation etc..and number 6 is the one that usually fails....ie, i wanted the worst reading possible to be the safest.
I have the apexi safc2 manual and it does not go into great detail, I was aware that I hd to connect the one wire and thats what I have now but what reading do I look for, I am gettn no readings???
Cheers Daniel
And thanx for the replys
Birnie.
I would like to do what you have done, but how the hell did you identify the back three pistons..
I need step by step guides please..car is gettn tuned on this friday at 3pm..
Chees Daniel
It is in the installation manual :D
Yep.... exactly as he said! I found the manual to be pretty self explanatory for this.... although my auto elec mate was doing the wiring and I was telling which wires were what from the manual... the knock sensor setup is the manual seperate from the wiring one... (SAFC2)
If I get a chance tonight il do a little step by step I find the manual :huh:
For correct wiring what you actually do is cut both wires, and connnect one wire to teh knock SAFC readout. Do the base test for knowck. Repeat on the other knock wire form teh engine, the higher of the two readings is the one you use, as this is the one that will have higher readings if the engine is detonating.
Once that is done, reconnect the cut not used wire back to the ecu.
Okay I will try again..thanx for the info guys muchly appreciated..
where are yous reading the knock from though on the safc 2...monitor mode ?
This is the issue I am having nothing is reading?? ill see how I go thanx guys..i do have the manual, I may of just been in too much of a rush to contemplate what it was saying.
Cheers D
What color wires do you have for knock 1+2 , when i did mine r33 S2 i had a clear colour sheeth for both knock sensors. i checked it 3 times but no reading at all. i just gave up in the end, when you get it going let me know what color wire you found it to be.
No, not monitor mode..
Go to:
3. etc. >
3. Sensor chk >
"Knk : xxxxx" will be displayed down the bottom of the screen..
This is where you take your reading from.
Owh i see, Very good. It does work. I thought i was good and i am. What is a good knock reading to have? It has been as high is 70 when i draged a taxi at the lights. anyone ????
There are two knock wires on the safc2, one purple and the other one is_____???
Does anyone know what color the other knock sensor wire on the safc2 is...
And I want to clarify that I join the 2 safc knock wires together then only join one to the ecu harness???
Kind Regards,
There is only 1 knock sensor wire coming from the SAFC II - the purple wire.
There are two knock sensors on your ECU. Knock Sensor 1 & Knock Sensor 2.
You need to get your purple wire (from your SAFC harness) and connect it to Knock Sensor 1 (on your ECU)- take the reading (as above)
Disconnect the purple wire and connect it to Knock Sensor 2 & take the reading.
Surely you received the manual when you bought it...? It's pretty straight forward if you have a read..
Edited by so_tred
I have done all of the above, the reason why i am clarifying wat I have done is because i get the same reading for knock 1 and 2...it reads the same all the time, at idling, when revving underboost normal driving conditions..it does not go up or down??
Also all wires are solded so i am sure of a good connection.
D
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
