Hi
I want project for 650 whp for my GTR34 V specII 2001 WITH OUT feul system !!
what is your opinions ? :P
please : but who is know with details !! injectors,,metal head with size??
intercooler size 2 ROW 3 ROW ,,
cam shaft (gear) lift & duration ...etc :O
and what about Apexi cam shaft 264 !!!!! lift I think 10.25 & from A better same camshaft with duration
AND lift OR DIFFERANCE ??? WHY :(
Thank you .
https://www.sau.com.au/forums/topic/164554-prject-650-whp/
  • Replies 84
ok...
i guess your 1st language isnt english...
are you tring to say you only want to run pump fuel? (fuel you get from ur normal petrol station).
and you want to run 2tanks? or are you asking you can run an intake fuel pump, and (or) an out of tank fuel pump? (maybe surge tank?)
https://www.sau.com.au/forums/topic/164554-prject-650-whp/#findComment-3049707
in for page1
ok
I mean change feul pump high pressore ,, injectours,, regolator metal,, turbo intercoler but i want fuel pump
in tank 1 or 2 I can that it ? or not .
GTR MINE's i think don't fit feul system !!! 600 whp !!
my gtr34 fit it intake system greddy complete exhaust . twin plate clutch nismo G MAX BLWOF VALVE HKS
x 2 .... twin exhaust manifold only ... :P
and my idia canceled up pipe for the turbo !!
https://www.sau.com.au/forums/topic/164554-prject-650-whp/#findComment-3049700
ok...
no no this is parts i fit it in my gtr only ...
but I mean i can fit it feul pump in gas tank !!! 1 OR 2 I don't like fit fuel pump out tank !
https://www.sau.com.au/forums/topic/164554-prject-650-whp/#findComment-3049723
can put an 044 intank with a bit of playing around.....
He appeared it is possible that is legal from then she dug you or from your experiment for the arrival to 650 WHP ??
WITH DETAILS !! please :P
and what is your opinion ( Apexi cam shaft ) 264 lift 10.25 ?
https://www.sau.com.au/forums/topic/164554-prject-650-whp/#findComment-3049748
Join today and ask questions without gramma in them, im not sure what this is intended but have to ask do you speak fluent english? Maybe inted your questions properlly, Are you trying to say that you have a 34 gtr without a fuel system, or what is the intended purpose of asking the question, What question are you trying to refer too?
It has no fuel system?
You want to upgrade the fuel system to support 650 rwhp?
What mods do you need for that power?
Maybe start with the basics:
What has the car got in it first?
What turbos, standard or aftermarket?
Best to list the mods it already has in a list form, maybe include a picture this will help :P
Aswell as where abouts are you? Australia? Are you on school holidays
Before we can help you you need to help us
Thankyou
Adam
https://www.sau.com.au/forums/topic/164554-prject-650-whp/#findComment-3049766
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
