  • Replies 84
You want to know what turbo and cam shaft to run to get to 650rwhp? Can i also ask.. where are you from? What is done to the car already? We can then advise what needs to be done to hit your power target.
Edited by fEkuaR
you are baby .... :sorcerer: :P
I think that !! :O
lol i think he is funny as :(
don't base your turbo choice on what cams you want, it should be the other way round. What you looking at using the car for circuit, drag or street?
WTF? I have no idea how to do it in a 34, wouldn't be that hard though, any good workshop should be able to do it.
cams depends on turbos...
ok ok
You are a good man :P
what is he Thats the suitable turbo for the Apexi cam shaft ?
Thank you
my gtr now stock engine & turbo ...
ORIGINAL ...
ok so its stock engine and turbos... What about exhaust system, Engine management, Clutch?
stock engine management :closedeyes:
greddy exhaust system evo II & dawenpipe ,, greddy intake system ( complete), twin plate clutch NISMO
G MAX,,TWIN EXHAUST MANIFOLD ...
big OIL COOLER greddy,, Apexi radetour,,oil catch greddy,,timer apexi...
but I want canseled UP PIPE TURBOS I think is better outbut for the turbo !!GOOD or NOT,, Idon't no !!
I need ECU apexi power fc pro D jetro ??... good ECU OR NOT I don't no !!
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
