Ok
so i have a problem
Basically, my master and slave cylinder arent doing anything
i cant pull fluid from the bottom with a speed bleeder, but none of the lines are clogged (ran air through everything)
and broke apart the master cylinder to check for bad seals etc etc
im ordering a rebuild kit anyways
Im using an r33 gt25t slave and master,
but i also tried a 260rs master as well.
i have elimnated the loop and its straight from the master to the slave.
any ideas?
pedal isnt kinked either.
https://www.sau.com.au/forums/topic/164664-im-stumped/
we tried for 5 hours today
beside, if you take the bleed screw off the side, it should damn near pour out, and it wasnt
also i have no speedo or tach.....but thats another problem for another day
https://www.sau.com.au/forums/topic/164664-im-stumped/#findComment-3051001
well after about 2 hours
we removed it, pumped it, stuff barely came out
so we broke it apart to see if there was a clogg, or bad orings, and after we put it back together, the fluid came out liek it was supposed to....but put it back on teh car, and nothing
https://www.sau.com.au/forums/topic/164664-im-stumped/#findComment-3051010
the thing in the middle that i take off all my cars with that big loop
no....
i never install it
But we DID try it with that installed first, but to cut down on fluid having to pressurize fr bleeding, we took it out of the loop.
https://www.sau.com.au/forums/topic/164664-im-stumped/#findComment-3051036
LOL double post
Well anywyas, im going tomorrow to order a master cylinder rebuild kit, anda friend is next day sending a RB20 master cylinder in case.
this thing will be working
if anyone can think of something else please throw it out!
everyone on my end is stumped
https://www.sau.com.au/forums/topic/164664-im-stumped/#findComment-3051059
I found you have to open the bleed nipples a fair way aswell, to get good flow.
we took them all the way out also
as well as taking off the main line going from the master cylinder and putting hte speed bleeder(its an air assisted bleeding tool) and it still didnt work.
and as i said, i blew through the lines, adn there was no restriction....its reallllly odd
https://www.sau.com.au/forums/topic/164664-im-stumped/#findComment-3051065
i would suggest that you have an air bubble in the top of the system somewhere when it is installed and no matter how much fluid you pump through there it will not escape unless you can find a way to get it so that the bleed nipple is the highest point of the system.
i have had the same problem with several of my italian bikes in the past and it seems to be the only way we could get the rear brakes to work on them at all, and we had to do this by removing the brake caliper from the swing arm and tipping it upside down so the nipple was above the centre line of the master cylinder.
hope this helps in some way?
cheers oxford
https://www.sau.com.au/forums/topic/164664-im-stumped/#findComment-3051133
Sounds like a master cyl problem. I read here somewhere that the seals turn inside out
sometimes for no apparent reason.
i was thinking that, thats why i am going to get a rebuild kit.
im just trying to make suyre that im not missing something simple stupid
as far as getting ht ebleed point as high as possible, the one on the side of the master cylinder is as high as it gets, and nothing was comming out.q
https://www.sau.com.au/forums/topic/164664-im-stumped/#findComment-3051142
sorry meant to also suggest removing the caliper/s from the mounts and getting them as high as possible too while pumping the pedal with a block between the pads so your pistons don't overtravel and come out, as there may be a spot that is holding air in the caliper?
if you work on an airbase there should be a nice steep load ramp or somethin you maybe able to use so that the front of the car is at the highest point then chock wheels securely, and remove calipers from mount and get them as high as you can and forward of the master cylinder if possible up ramp, pump fluid through manually until you have some thing like pedal feel, then start car and continue process, as the brakes are vacuum assisted they sometimes won't bleed properly until there is vacuum in the system.
good luck
cheers oxford
https://www.sau.com.au/forums/topic/164664-im-stumped/#findComment-3051182
fill the master 1/2 way or so and put the compressor onto the top of it and blow it through so it starts feeding to the slave. or u can take the master out and fill it with oil when it is disassembled so its not full of air behind the piston.
mine had same issue and the compressed air sorted it str8 away :bunny:
https://www.sau.com.au/forums/topic/164664-im-stumped/#findComment-3051200
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
