Hey, urgent question!
I am buying the CLARION VRX765VD from ebay, its being sent from America. But before I make the payment, does anyone know if this will definately work for Australian formats?
Will it work with Australian DVDs, Australian CD's, Australian Ipods etc. ?
I understand that the Australian model is called the VRX766VD....they look totally the same. Wat do you guys rekon? (Im getting the VRX765VD 500 bux cheaper then the VRX766VD (retail) )
https://www.sau.com.au/forums/topic/164847-would-the-vrx765vd-be-compatible/
The VRX765VD is designed to play Region 1 DVDs (Aussie ones are Region 4). So no it won't play them, and as far as I'm aware there is no way to unlock the VRX765VD.
Hence one of the pitfalls of buying international. No local warranty support, some features may not here.
How much are you paying for it by the way?
790 for the VRX765VD
or
1300 for the VRX766VD
Razorsharp, are u 100% sure?
http://www.clarion.com/us/en/MungoBlobs/44...RX765VD-ENG.pdf
Manual, page 21: "...will only play DVDs with the region number '1' or 'ALL'"
CDs and Ipods should play fine.
Weigh it up.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
