Ok, i figured other forums i frequent have them as well
please post as many specs of your wheels as possible
width and offsets being the MOST important
Picture from the side straight on, and one from the front straight on (to see if they stick out, or sink in for fitment wise)
ill start
Stock M35 wheels.
15mm spacers front and rear to clear GTR brakes
225/50/17 tires
17x7 id imagine is waht it looks like
Work euroline
18x9 -5
18x0 +20
235/40/18
above is with stock fenders
below is with midified fenders
Work Emotion XD9
18x9 +20 all around +20mm spacer on the front
225/40/18
please contribute
https://www.sau.com.au/forums/topic/164936-post-your-wheelstire-size-and-specs/
  • Replies 67
17 x 9 - Standard R33GTR wheels with 245/40/17's
Pictures are at 340 mm front and 330 mm rear, which was too low. It's now at 355 mm front and 350 mm rear, much better ride and handling.
:D cheers :(
  • 4 weeks later...
18x10 +20
dont get a 10 in the rear unless you get at LEAST a +10
but hten you will haev to do an agressive roll and pull in the rear.
anything less will hit your coilover.
18x10 +20
Your using 235's on 10 inch rims as per per your first post?
They would look mega stretched?
A "normal" person would use a smaller width rim and run the correct width tyre for comfort, looks, handling and safety
am i normal?
I use a 225/40 on a 9 inch wide and a 235/40 on a 10 inch wide
its about clearance, the stretch in the sidewall allows you to run a wider/lower offset without fear of rubbing so when the camber changes in a turn, it acts like a circle and not a square like a normal tire
am i normal?
NO :thumbsup:
That's why you should explain or clairfy when posting esp when people are asking a question about a topic they do not know anything about. Otherwise someone is going go and buy a set of wheels too wide or the wrong offset and have to beat the shit out of the rear guards and run a way too narrow a tyre for the rim size.
18x10 +20
cool...thanks grant.
mate has a set of eurolines ..18*9 and 18*10 ..both with +35 offset...i'll try them for fit this weekend....oh and tyres are 235 at the rear too...really stretchhhhhed
Running Advanti Racing 'Karla" wheels:
Wheels: 19x8 +35
Tyres: 245/35 R19 Hankook K104
They are being replaced (due to a fault) with Enkei RP03 model which should fill the guards a little more, I think.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
