Big Thanks to OZ and Family for having us over and putting on lunch!!!
The cars look great and had a great time :P
There were funny times in the day.....
My favourite was the guy that came past in a old Laser acting silly asking if the cars were skylines and what models were what lol...I told him to do a burnout and he said he would go and get his baby godzilla im like " no just bag up the laser" he took off and about 30mins later turns up in Bayside Blue R34 GTR and was a very nice looking car indeed...I was like you lie thats not a baby godzilla thats a big one :laughing-smiley-014: :laughing-smiley-014:
Made my day!!! :P
Classic.
Wish I coulda come I had to entertain the inlaws to be though... nightmare of a day !
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
