  • Replies 106
Posted Images
Yes, that's what i meant. Airflow is 1080-1100 when on idle.
If i rev it does go back to the same level.
Is that a bit high?
I wonder if I've soldered the wires incorecctly but i thought it wouldn't work at all if i did that.
It's a series II so i had to share the 2 ground signals (from memory)
Also, I've been looking around at maybe getting a replacement or still hanging on to the fact that this one is OK and just set up wrong.
I saw a unit on the Jap Auctions and looks as if the signal ground (guessing) has it's own 'C' clip that would bolt onto the body for grounding rather than going thru the ECU.
Also, that wire was extra long on the Tomei plug which suggests it should be different and had the length to be wired into the chassis.
Would this change the behaviour of the signal overall?
..and, if peeps are looking at getting one, they are on nengun as a Tomei branded Z32 for $360 delivered.
If i get a replacement, i think i will get that one.
It's so much freeegan hassle to get around this and i don't wanna risk getting another dodge one.
And that is possible as i don't think these other dodge ones were sold to rip people off, just the seller, even reputable sellers, didn't know about this bad batch ???
Anyway, just putting it out there as an option, bit more expensive but only $50 over the cheapest I've seen.
Yer, they're the ones i just got and will be installing within the next few days.
Funnily enough tho, they came in a what looked to be a genuine nissan box :D
Thats correct as its not a genuine Nissan part number - Its a Bosch part number
The Bosch Z32 AFM still has the Nissan (JECS) part # on it (22680 30P00 A36-000 N62) and the Bosch part # is on the box (F00E000202).
Is that a bit high?
I had a look at datalogit log I took some time ago.
My Z32 afm on idle see's 1165mv on average. It never sways more than 10mv either way providing I don't touch the steering or pump the brakes. :stupid:
But it is a 3ltr so it 'may' suck a little more on idle.
Yes, I got the dyno done and the replacement Z32 is working fine. Not so happy with the power output though of 200kw non shootout mode. It is a low reading dyno, but I was expecting more power.
At 1.3bar it's making 190kw at 5500rpm, but then it just flatlines the power curve. Even at 1.5 bar it gives slightly better mid range, but the same flattening out of the power curve occurs. The boost does not drop off at all with the AVCR, it holds steady to redline. My tuner thinks it's the justjap intercooler I bought, and suggested that I replace it for a thicker ARC item with low pressure loss. The AVCR Duty cycle is at 40% and holds boost steady. Knock count is at 14 W.O.T. with an AFR of 10.0 from 6000rpm to redline.
What I have is;
Series 1 RB25DET with 1.8mm headgasket. (newly built with 6000km run in)
Standard cams
Apexi pod filter & Z32
Greddy Inlet Manifold
Apexi Cast top mount exhaust manifold
Garrett GT30/40 .63
Tial 38mm external wastegate
Greddy Type R BOV plummed back
Power FC and AVCR
720cc Nismo's.
60x30x76 tube and fin FMIC with 2.5" piping throughout.
3" exhaust from the turbo back.
Should I put money towards an ARC intercooler, or should I install a set of 256/264 hks camshafts next?
Is the 1.8mm headgasket lowering compression so much that it is effecting the amount of boost I have to run to reach my target of 250kw?
Edited by silman
Well Silman, at least the Z32 is sorted
Did you find when you swapped it over and started the engine, it was crap idle and needed an obvious retune, or was it still OK to drive just with more room to move on the verticle axis?
Birnie - is you new AFM working well now? Has it been tuned.
1. Is there any comparison Dodgy vs New with regards to volts at idle?
2. Anyway we can tell a bad one before the tuner has almost completed a tune
I am getting a new one, making sure it doesn't have the Nissan embossing but not sure what else I can do..
Cheers fellas
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
