My new Tomei (Nissan) Z32 was delivered today
The mesh looks better
The sticker looks marginally better, and slighly different design.
There is definatley no mention of 'Nissan' imprinted in the plastic.
From memory, the sensor looks to be a diferrent colour?? (maybe wrong there)
The top plastic cover plate looks to be a bit dogey though, although if all the interior bits are OK, it won't make a difference.
Here's some pics....
  • Replies 106
Posted Images
Ben,
Yep I'm around the same volts as you and suspect same power; all though I never did dyno it once it was running properly. I went to give it a power run and it was pumping the lifters; that was sorted and never threw it on the dyno again. :D
But yes ~4.3v and it made 180rwkw then valve floated and power dropped.
The stock afm was max'd out, dropped the z32 in and was around 4.3v as you are. Stock 270cc injectors were maxed out also. :rofl:
Same boost levels too but with vg30det turbo. The heads had a little work, usual port/polish, multiangle valve jobs & valve deshroud.
There's quite a big difference in airflow from 4.3v to 4.7-4.8v. Another mate was maxing his std afm out at ~180rwkw, dropped the z32 in retuned and did 4.7v at 270rwkw.
Won't be long before I'm pushing the boost up with the gt30; should get my rb26 pfc and fit it up this week.
Nice to know cubes. Should go well once you tune it up and get the gt30 going!
Ive got to put my 450cc S15 injectors in then I'm heading for a tune also. I suspected that the difference between 4.3v and over 4.8v would be pretty huge.
I'll be happy with about 230-240rwkw.
Hopefully I will get the flow reversion thing sorted.
  • 3 weeks later...
OK peeps,
Finally swapped AFM and had a tune
It works ! Yeah !
Just swicthing the AFM bfore goijng on the dyno and the car is started and hiccupping and splutterring and telling me "PLease Birnie, i need a tune now" which is the result i was after/expecting going from a dodge AFM/tune to a good AFM.
All tuned and it hit cell 16 down the vertical on about 17psi ( i think that was about 4400 on the volts reading)
Before with the exact same setup with dodge-AFM it hit cell 20 on 13psi.
So as far as I'm concerned, the dodge ones ARE out there.
I don't actually know but i still suspect a bad batch going around rather than some dodgey chinese peeps trying to rip people off.
So yeah, if you happen to get a dud, check fr leaks first cause i had some shockers, but other than that, take itback and ask for it to be checked or replaced.
The worst part is you lose your tuning money which really sucks cause that's the most expensive part!
Luckily i had the 1st tune done on the road with a bud so i was only out of pocket $200
So there you go, I'm sorted.
:thumbsup:
i tested out my mates rb25 afm the other night. at 13psi with a 3076 it was reaching 4.9v and that was only about 270hp. we are going to remove it anyway so that isn't a big issue, but first we need to sort out a few issues we have, such as the intake pipe sucking shut, and an overly restrictive intercooler.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
