Does any1 rekon the boost 98 from united helped me along at all...
Im quite interested in fuels and their advantages and thats the reason why I choose the boost98 as it has sumting like 5% ethanol in it...Ive read quite a few articles claiming its miracles, the ethonal that is and how it has to be tuned to it...
Before I got it tuned i used bp 98 and boost 98..untuned the bp98 felt way better, the ethonal decreased power.
I wanted to use shell v-power racing but I cant even find it in sydney yet...
Let me know your thoughts...im still wondering why the power was so high..the dyno is a pretty average reading dyno(DD) aswell.
Cheers
my car is tuned on shell v power 98
i tried a tank of ultimate recently and its knock went from its usual max of 20 up to 70
not impressed i went back to v power and the knock stopped.
havent tried boost 98 but i think its the same blend as shell with a 5% ethanol
Darren
  • Replies 58
Darren
Darren,
BOOST98 and v-power racing do have the same blend percentage of ethanol though I would think the qaulity and R&D of the shell fuels would be better, as they make a stack load of different race fuels and chemicals...toluene for eg,
I was hooked ever since i read the thread in zoom or hpi with that 32gtr gaining somewhere near 20rwkw with just the changing of fuel from normal 98 to ethanol enhanced fuel..
D
There are quite a few servos in Sydney with Shell V Power Racing 100 ron, they are listed on the Shell Web Site. We use the two on the Princes H'way, one at Carlton, near StGeorge Leagues Club or the one at Gymea, city side of the High School.
In a Shoot Out dyno graph, I would be concerned with the inlet air temp being 60 degrees with an ambient of 27.
I am not sure why he insisted on doing it in 3rd gear. The constant threat of kick down prevents proper tuning at those rpms. We always tune autos in 2nd gear, much less chance of kickdown. Or better still lock it in 3rd. For the Stagea we use 2nd gear and select the snow setting, that locks out 1st gear anyway.
:( cheers :(
SK,
The 3rd question is a question for the tuner, Im sure he has a good reason for using third..
I will have to look at the website...though I live out in sydneys west and all the shells do not have this fuel as far as I am aware...
I will be taking it out to WSID to see if the power reflects the cars mph...
I am not expceting a good time, but the mph will hopefully show its future potential...
the stock auto gearbox is slowly dying..im better to take my foot of the accelerator then keep it flat between gears. Next mod will be to do something to the auto box...
Cheers
Also,
The plan is to go to WSID on anzac day...GUESS what time or MPH I will run????
Im thinking 13.5@105mph with a 2.2 60ft as the car doesnt move much until 4000rpm where it wheel spins until second then just pulls and pulls...
Cheers
I'll be there at WSID on anzac day to race you :P white series 2 r33gts with gtr32 rims up front
with 234rwkw you should be expecting around 108-110mph at least but i dunno if the auto affects it.
hope your enjoying the new power :action-smiley-069:
Thats what I was think but the auto doesnt change gears good at all and thinking I may loose mph because of it..thus the low 1/4mile time also...
Im sure with a proper auto and good tyres with a good 60ft this power should net a 12.6-12.8 time.
i personally wouldn't flog the auto to death on anzac day.
by all means do a run or two, but by not having a shift kit and a trans cooler your asking for trouble.
each time it tries to change gears its going to shred your stock bands in the trans and cause enormous amounts of heat.
especially if your already having trouble with it shifting.
just be careful is all im saying otherwise you will be walking home...
Youre right dangerman I am a little worried, but cant fight that urge..
I was thinking of stalling it up on the stock convertor but I may not even do that...see how it goes.
Cheers
  • 4 months later...
Hi All,
For those interested just a few updates on this car;
AUTO DIED (RIP)..Not really a big surprise, but it did last a long time with a fair bit of abuse with no cooler.
Now have the following to replace;
Nismo lightened flywheel
Nismo/Exedy 4 puk brass button clutch (pads are thin, race clutch..bites hard)
1200kg pressure plate
R33 5speed
I am doing the conversion now..
Also parts upgraded
- Putting heat shields back on the turbo and manifold
- Fixing the exhaust wrap that was ripped off the bottom of the dump (too low) :)
-Wrapping the exhaut up a bit more past the cat.
-Cat colapsed (Catco 3inch) so deciding what to do here. Only one side colapsed by the looks of it so might just take half of it out.
- Installing electronic boost control device, HKS EVC3..Not sure what boost level yet.
-Finally going to install my GTR fuel pump. The standard fuel pump lasted 4-5months no worries there so that proves a point to some - I think.
- Wanting to change the inlet from the pod to the turbo to a solid type, ss or silicone. I think it will start closing shortly if it hasnt started to already.
- Enclose pod filter...I put the standard air box back on for a while but I noticed it lost power when getting speeds up..but it was a little more responsive. I have two cold air feeds to it as it stands.
When I do all this I will be taking it back to get retuned at hitmans....maybe guess the power for the changes made. My injectors wont like me though and the stock AFM..not wlling to change these though so power will depend on these items.
Cheers...
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
