I have recently upgraded my skyline with full exhaust and electronic boost controller,
I am interested in more power though and am considering in a turbo of capable of higher pressure and FMIC.
There are turbos on ebay for around $300 and FMIC for around $300 aswell, Has anyone purchased 1 or I would like some opinions?
https://www.sau.com.au/forums/topic/165424-turbos-and-intercoolers-from-ebay/
the cheap generic 600x300x76mm intercoolers are fine. Im sure LOTS of SAU'ers use them.
a $300 turbo on the other hand, not so great.
Yeah I have been reading on forums and seems that FMIC dont matter 2 much.
But what turbo then 2 buy I dont want 2 fork out 2 much any suggestions??
what motor is it? RB20 or RB25?
if your looking to do a turbo upgrade, there are more things to factor in than just a cooler upgrade.
the ecu would need to be modified or replaced, possible injector upgrade, a larger fuel pump, a stronger clutch, air filter upgrade etc etc.
i would rather buy a second hand brand name turbo then a brand new Ebay turbo.
$300 for the turbo, then 2 weeks later...$900 for rebuilding the turbo...OR possibly worse if the front wheel went into the engine...
can anyone point me in the way of buying a cooler my skyline, have only had it for around 3 weeks looking for somewhere to buy one, but a decent one
http://www.skylinesaustralia.com/forums/in...howtopic=138738
there are items on ebay, and there are items on ebay
some are completely dodgy items :
scams, electronic superchargers for 75HP which are a fan in the intake pipe on an n/a car
those 5HP resistors etc
600HP turbos for $600
not hks apexi nismo greddy tomei ashtray
dodgy traders
then there are good bargains well well know traders and shop "runners"
usually have really high feedback and sell good stuff just cheap
without the added bullcrap of running a normal retail store
choose carefully but remember there are lots of bargains
just be careful, double check, ask, lots of reading and check their feedback
I have RB25, I wouldnt mind 250rwkw, What are the capabilities of stock injectors?
I was told i should be able to get upto 15psi on stock injectors and ecu.
for that power you will need
- ECU - PowerFC, wolf, halteck, autronic (to remap fuel etc)
- New fuel pump - about a 500hp internal will be good
- Turbo, not an ebay turbo, a high flowed will be best as it will bolt straight back in so you won't need a new manifold or dump pipe and existing imtercooler
piping can also be used
- intercooler, hybrid are cheap and a decent brand
- injectors (recoomended)
with the injectors they should be able to to achieve that but you will need a new fuel pump and fuel pressure reg.
but keep in mind the duty cycle of the injector will be above 85%, so an injector upgrade will be good to lower the duty cycle.
550cc nismos are a direct replacement
Edited by 33_skyline
somebody should buy them and see how they go ?
there onli 300 bucks and they could onli blow not alot of money realli?
i mean hell most of the shit we pay for in the high labour costs, thats made in aust anyway
hrms, not too sure if the stock ecu can handle 15psi...
anything over 12+ psi and your in rich and retard territory. though some sau'ers are lucky to get 14psi with no rich and retard on the stock ecu.
just my two cents...
cheers
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
