im looking at upgrading my turbo soon, and ive been told by number of people to go for a gt-rs, i have recently discovered that both garret and hks make a gt-rs, are these turbos the same or not, im looking to make about 270 - 300 rwkw on my r33 series 2 gtst, can any one give me some suggestions or advice,
thanks
https://www.sau.com.au/forums/topic/165591-turbo-question/
