Just bought the 678 from Supercheap, let's see how I go getting it on the car..
Turns out it's pretty much plug and play, just needs a custom bracket. It's a good fit and no clearance issues with the front mount either, just need to move the horns out of the way a bit. I might post some photos once it's all back together and tested properly.
Here's some photos of the auto trans cooler install on an R34 GTT Tiptronic auto. As per above, it was a very straightforward install as I just replaced the stock cooler with the Davies Craig Hydra Cool Transmission Cooler (Part No: 678). It was $139 from Supercheap Auto, and I also got a 'pod filter bracket', which I modified to suit.
There was very little fluid coming out of the original cooler as per the photos, so I didn't even need to top up the ATF (recently serviced and sitting slightly above MAX). The car had been sitting for several days prior to this, maybe that is also why the cooler was fairly dry. The only issue was getting the original hoses onto the new cooler as the fittings are slightly larger, it took a lot of pushing and swearing.
The install itself took probably two hours, however if you have a front mount be prepared to take it off. This means removing the undertray, front bar and reo for hours of entertainment.
Useful threads:
Pics:
Original transmission cooler:
Original transmission cooler off and fluid out:
Size comparison (note the DC cooler is about 2/3 of the thickness of the OEM unit):
New bracket in place:
New cooler installed using original hoses:
Clearance between transmission cooler and intercooler:
  • Like 1
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
