260kw on stock injectors with all other supporting mods using slide hi-flow running 17 psi. Also the use of a nismo fuel pressure reg helped.
IMO all the supporting mods for that output would include injectors. The duty would be close if not 100% at high RPM i.e. it its static.
Its is not recommended to exceed 80% duty cycle. Otherwise you will run the risk of the injector not being able to open and close quickly enough, which causes the injector to float half open. This may lean the mixture out, which is not going to healthy for an engine at high revs and under full load which is where this occurs. Under static conditions the injector cannot control fuel delivery anymore and based on this my assumption is why ppl see good results from installing an FPRs to simply add more fuel under this circumstance. IMO this would be the caveman approach.
There is an arguement that it only happens at high RPM and that doesnt happen all the time. As mentioned before the AFRs would be a good guide to see if this is happening.
IMO if ur spending the money on everything else just buy some 550cc NISMO ones and be done with it for an app under 280 rwkw
550c NISMO injectors, would they manage at 300kw?
Also, when replacing the injectors, how long after until you consider changing the fuel rail and fuel pump?
Any need for a rising rate regulator....
I doubt u will get to 300 without a new pump.
also running 235rwkw on stock injectors and stock pump, no reg.
Ive also heard of people running big power (300rwkw) with stock injecctors..and I heard this from an exerienced tuner? But from what these forums say its impossible to run this/or dangerous to do so...it might be I dont know?
Im assuming that it may depend on the tuner and how he tunes it...People say rb25 AFM need to be upgraded over 220rwkw..mines fine at 235rwkw.
Its also good to consult with a tuner as they are the ones tuning these things on a daily basis and some for a long time.
my 2c
I wish i knew the explanation of different parts maxing out at different power. I know that no 2 parts are the same, though I have a good feeling is has sumthing to do with the tune.
Cheers
it has lots to do with the dyno IMO
it probably has most to do with that . the only other factor thats variable here is AFR , a lean mixture will make more power with less air and rich mixture will require more air to make the same power . i would expect most people who have a tune though will know what to look for in their AFRs so most tuners would be roughly the same as they are aiming for good AFR curve , so not enough to produce great variences . there will also be some variance in the calibration of each individual AFM , they may vary voltage slightly for a certain amount of measured air due to age or tolerance
but to get 30-40 rwkw difference i would say it would be mostly dyno variations with a bit of the above . i know my figures were on a notoriously conservative dyno
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
