Specs are as follows.
Drop axle (designed for LOW cars)
Beaver tail (4" rear bed drop, again designed for use with low cars)
Extended draw bar for extra stability, specifically at highway speeds.
FIVE near NEW tyres (Done a few thousand klms)
Heavy duty winch.
Hydraulic disc brakes on front axle. Work very well.
Roll-formed guards
"nerf" bars
Checker-plate floor
Front cross bar has been kept LOW to enable lowered vehicles to overhang without tearing off bodykits etc.
Ramps slide away underneath rear of trailer for safe storage.
Trailer weight = 480KG!!!!!!
2 Tonne GVM
Rego till december 2007.
Even with my car riding 87mm off the ground (at the chassis), i have only ever had the exhaust scrape slightly........I cannot stress enough.........this trailer is great for LOW CARS.
I have travelled as far as Melbourne and Adelaide wih ths trailer, and found that even at highway speeds it is very stable. Most of you have seen it at the track, or even on the road, i have had a few people actually comment on how "stable" it sits when towing.
Unfortunately my digital camera is not working at the moment, but i have a pic of about 18months ago. Not alot has changed other than new tyres being fitted and it has sustained some stone chips from interstate travel.
It is painted in grey hammertone, this was done so that future touch-ups or respray was easy.
This is not a cheapo trailer, i have priced these up locally with similar specs new, and was quoted from several different companies around the 5000 dollar mark (with second hand tyres and no rego).
I am looking for $3400 O.N.O. for this trailer.
If you are SERIOUS and have dollars available........Give me a call on 0402 807 417 to organise viewing etc.
Trailer located on the Gold Coast.
Please note.........URAS front bar (not pictured) DOES fit on car when on trailer
https://www.sau.com.au/forums/topic/165928-car-traoer/
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
