hey tony
might not be the clutch itself mate. check out the housing of teh gearbox and oil up the lever and clucth cable and anything that activates the clutch.
if that dont work, buy a new clutch lol
daniel
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
