IT should be your oil light... correct if I'm wrong as the pi is quite small... it should show that there's something wrong with your engine's oil...
I'm pretty sure...
would get it checked out if it's always showing you this... if not this, might be your radiator light?
https://www.sau.com.au/forums/topic/166055-question/#findComment-3074627
I'm pretty sure...
The oil light is red, the check engine light is orange.
https://www.sau.com.au/forums/topic/166055-question/#findComment-3074641
I'm pretty sure...
maybe engine oil is a little low would u say ? and if it is radiator wats the problem there?
https://www.sau.com.au/forums/topic/166055-question/#findComment-3074652
yeah agreed.....
but if the oil light isn't on (and if it is you should;ve already kissed your engine goodbye) there will be another problem
as said... runa quick check on the ECU and all should be fine....
either that or take it to a mechanic....
https://www.sau.com.au/forums/topic/166055-question/#findComment-3074660
Is your car missing at idle or sputtering when you get up it? Could be ignition problem (as in coils) Are they the factory coils and how many k's are on the car?
yeh its on stock coil packs at 5700 km
but when its coil problem the traction control light and other come on aswell rite?
https://www.sau.com.au/forums/topic/166055-question/#findComment-3076912
depends, mine is currently getting new coils as mine kept missing and dropping a cylinder. The only light that came on was the engine light so it could very well be ignition related. If your having similar symptoms to me its most probably your coilpacks.
https://www.sau.com.au/forums/topic/166055-question/#findComment-3078013
atm i don't know becos its not miss firing.
does the missing happen straight away or later on as u drag it on
https://www.sau.com.au/forums/topic/166055-question/#findComment-3082307
I think it depends on how bad the faulty coil is. Mine started missing before the engine light went on and a guy on here by the name of alexr34 had no problems at all except his engine light went on. They both turned out to be the same problem. If in doubt take it to a mechanic that can do a diagnostic on it and it will tell you which error code is causing it to come on. Or if you like to do things yourself I think there is a thread on here showing you how to check the error codes for yourself. PM 666dan and he should be able to help you.
https://www.sau.com.au/forums/topic/166055-question/#findComment-3082575
my guess! this is an engine check light with most cars they will come on momentarily after start-up, this is normal from new. If the light stays on it could mean the engine has reached 100,000 klm and now needs a major service ie timing belt or the like.
https://www.sau.com.au/forums/topic/166055-question/#findComment-3095733
mines almost 60000km and the light gone out its been around a week now since its gone out
so for now not really worrying
until it comes back on again
https://www.sau.com.au/forums/topic/166055-question/#findComment-3096019
Oxygen sensors......???
Faulty coil pack.......???
Faulty wiring or Spark plugs....?????
AFM's..(High knock levels)...................???
These can all send the light on.
Best is to read the codes....find the error and address the problem.
Cheers
https://www.sau.com.au/forums/topic/166055-question/#findComment-3096077
Cheers
high knocking levels ? wat kind of knocking we talking about? coming from where
https://www.sau.com.au/forums/topic/166055-question/#findComment-3103334
knocking / pinging / pre-detonation. in the engine. generally happens under load because of bad fuel / bad tune, the engine will make a distictive rattle when loaded up under acceleration. If you hear this back off drive steady get it fixed.
means the fuel is igniting before the piston reaches the top and the spark hasn't fired.
https://www.sau.com.au/forums/topic/166055-question/#findComment-3109551
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
