Hi,
I'm currently looking at buying a Nissan Stagea that's yet to be complied to save myself some $'s. I'm located in Adelaide, and the car is in Melbourne. What are my options? Can I get it complied in Adelaide if I buy it and drive it back with trade plates? (I can borrow a mates plates). It's a completely stock S2 RS4 Neo.
Thanks in advance.
Edited by webng
https://www.sau.com.au/forums/topic/166191-compliance-options/
Id forget about buying an uncomplied car altogether. Although you might save some $$...that will be made up x10 by headaches and stress, i guarantee it.
Agreed.
The few of these that I've known have been bitches.
What often happens is someone imports it, and may not like the car, usually because it's crap. So, they recover the money by on selling.
To comply it you'll need a lot of paperwork (De-reg info, customs info, etc.) and chasing it up in a different name is a pain in the butt.
If I can offer advice, I'd say avoid it.
Ask him to get it complied and rego'd, adding the cost of this to the car.
The better option would be to contact J-spec or prestige and import it yourself though.
It's all your choice, but I am yet to hear good news from people buying uncomplied cars, and several bought cars that could NOT be complied (due to rust in towers, conflicting engine/ chassis numbers, too many aftermarket parts, etc.)
I'm sure there must be some people who have bought a bargain, but I'd advise against trying, especially for a stagea. They'r
e too nice to do it half arsed.
exactly how do dotars feel about changing raws after the import approval has been submitted ?
I know of a couple that have happened because raws went bust/closed down ect but they seemed to want reasons
can you just do it if you change your mind or buy the car before its complied off someone else ?
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
