hiya
do 32 vspec gtrs run the same brembo calipers and brake pads as the other gtrs ? rotors seem to be identical but not callipers ?
i need some new pads for my 32 vspec II and they seem to be different to 33 gtr pads
could anyone give me the nissan part numbers I need for front and rear pads ?
also on nengun its the same part number for endless pads all the skylines and s14/15 including vspec 32 so i am a bit confused
EP230 R32
AU $ 142.48
Nissan - skyline R32 (GTS-t.Type-M, GTS-4) BNR32(GT-R V-Spec) R33 (Turbo) ECR33(Turbo) ER34(Turbo) - Front
EP230/EP064 S14
AU $ 284.95
Nissan - Silvia S14 - Front & Rear
EP230/EP064 S15
AU $ 284.95
Nissan - Silvia S15 - Front & Rear
EP230/EP231 ECR33
AU $ 284.95
Nissan - Skyline ECR33 - Front & Rear
EP230/EP231 ER34
AU $ 284.95
Nissan - Skyline ER34 - Front & Rear
EP230SSS Z32
AU $ 142.48
Nissan - Z32( 89/7-02/8) Silvia S14, S15 - Front
EP231SSS R32 REAR
AU $ 142.48
Nissan Skyline R32 (2 Pot) R33 Turbo ECR33, Z32 (from 89 -) REAR ONLY
https://www.sau.com.au/forums/topic/166341-32-gtr-vspec-calipers-and-pads/
nengun also has different part numbers for 33 and 34 pads , are they realy the same ? now im really confused
41060-12U87 BCNR33 Front
AU $ 419.82
Nissan Skyline BCNR33 RB26DETT (Front Only)
41060-12U87 Front/ 44060-12U87 Rear BCNR33
AU $ 777.84
Nissan Skyline BCNR33 RB26DETT (Front & Rear)
41060-AA393 BNR34 Front
AU $ 419.82
Nissan Skyline BNR34 RB26DETT (Front Only)
41060-AA393 Front/44060-AB085 Rear BNR34
AU $ 777.84
Nissan Skyline BNR34 RB26DETT (Front & Rear)
44060-12U87 BCNR33 Rear
AU $ 411.42
Nissan Skyline BCNR33 RB26DETT (Rear only)
44060-AB085 Rear
AU $ 411.42
Nissan Skyline BNR34 RB26DETT (Rear Only)
ah, well depending on how strict your SEVS workshop is you will need to buy the original nissan/brembo pads.
the front pads are 41060-12U87 and the rear pads are 44060-12U87 cost around $450 for front and same for the rear. they are quite good pads though, so it's not a complete waste of money. last a long time, and good for street/hillls driving. and ok for a little bit of track.
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
