had a little off last night in the hills, bit spewing cause it was right towards the end of the night last few corers from chain of ponds so im very familiar with the roads too
on the upside its minor and superficial could of backed myself into a gum tree and would be spewing even more
heres some pics might get chips and dents to take a look and see what they think alot of the front guard can be cut and polished to look a lot better and same with rear quarter
speed was not the cause of this accident was my back end steping out round a corner and when backwards though a barbed wire fence
post-13315-1177726461.jpgpost-13315-1177726694.jpgpost-13315-1177726724.jpgpost-13315-1177726760.jpgpost-13315-1177726953.jpg
https://www.sau.com.au/forums/topic/166365-carefull-in-the-hills/
  • Replies 47
Don't think a cut n' polish will get those scratches out. Looked like a respray is in order.
some of the scratches have a real whiteness to it cuting that will make it look a little better i am very well aware i will probably have to spend near on a g to get it all back to the way it was
Damn Steve sorry to hear about that! Atleast you came out alright and everything else is fine. You seem to have a good attitude towards it too. If you want me to recommend you an awesome crash repairer that does some great work, PM me, they are near us so you won't have to go far to get a quote :D
http://www.metacafe.com/watch/501379/remov...with_airduster/
give that a try on that dent... i always wanted to see if it worked but didnt want to dent my own car...
take it easy up there today if anyone is going for a cruise, its practically a river on some roads.
i think cut n polish made it look a little better only did bonnet and front fender
can u get a can of that stuff will try it for sure
Edited by Madaz
^^^^^^ WHAT THA....lol
typical whore response...
hey madaz, u can get airduster stuff from officeworks or any place like that... all u do is turn the can upside down and bingo, liquid CO2... use in a well ventilated area.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
