im about to start a high hp 30 motor. i know most of the things require but have i missed any out and what weakness are there at 700-800hp.. i dont want to do anythin thats not realy vital but any suggestiong would be great
30e block..30e crank will need big end grinding..
carrillo rods,, wisco pistions (good coice?)
std gtr oil pump ?ok?
knife endged and balanced crank (inc flywheel & power enterprice pully)
and thats pretty much what def will be getting done..
will be for dyno runs only at high power.. and maybe drag at lower power levels,
things im not sure about are (to save on build costs)
o ring block? or any extra block strengthing.
trust oilers on main bearing trust?
head studs? main studs? vs std gtr ones.
any heat treating/coatings?
26 mains and grinding channel in 30e block?
oil squirter fitting?
or any think else i have missed?
i dont want to do anythin thats not realy vital but any suggestiong would be great. ps that 30 post is far to big and its full of crap most and cant sniff out important info..
std gtr oil pump ?ok?No, at least an N! pump with crank collar
knife endged and balanced crank (inc flywheel & power enterprice pully) I also got the crank cryogenically treated
o ring block? or any extra block strengthing.Not needed
trust oilers on main bearing trust????
head studs? main studs? vs std gtr ones. Yep, ARP do these, retap block to take Rb26 head studs
any heat treating/coatings?Recommend getting pistons coated
26 mains and grinding channel in 30e block?????
oil squirter fitting?Good idea, but aparently very difficult to do(about to find out)
its because the info is so bitsy its spread out on the sticky and most people arent actually answering the questions just talkin shit.. kinda like now.. if you canno help be please dont bother posting... anf you rite.. i dont have 3 weeks either.. i would rip my hair out before then im already since of the smack talk on there..
For a 'reliable' 700-800hp, everything will need to be modified or changed, particularly the valve train and head porting (you are using the SOHC 12V head, yeah?)
what is everthink..?? what have i missed mentioning
im using nothing less than a rb26 head jun intake 85mm throttle medium porting and mild apexi cams & pullies.. im more consorned about the strength mods not the head mods.. i know my head and turbo setup can make the power.. i just want it to hold down below..
can anyone helpme on some of these things..
whats required and whats not or any others i have missed
Edited by GDZ1LA
i just built mine to handle 700rwhp tops
basically need everything done yes.... pm me for more info, i could try send ya a list of my mods, theres just way too many here to list
get 1/2 inch head studs, block studs, if u can get the turbo, mani and dump coated then do that, i use a trust oil pump, was using gtr oil pump before but definatley dont want to risk it.....
ben...
GDZ1LA - Please read the RB30 sticky and also search.
There is more than enough info on what your asking about this forum.
People cant be expected to answer/repeat themselves time and time again.
If you do truly want to build a 700-800hp motor, then taking the time to read a detailed thread should be the least of your issues.
Rushing into a build is what will be the sad end to it.
Thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
