  • Replies 135
Hey
would you still have any left? Id like one for the R33 please.
Thanks.
Vincent.
Hi Vincent,
Pm sent
Payment received
I will send it off ASAP
Regards,
Sherwin
Sherwin, i sent you a pm dude. Il send you tha cash on friday man. Can I still get one?
Hi there,
Yeah, that's not a problem.. I will wait for your PM with delivery details :)
All PMs have been replied to
Regards,
Sherwin
Recieved lock bar yesterday and will be fitting it tomorrow night. Will let you know how it goes and if it fixes the problem of the rear end floating around from the faulty hicas sensor.
Cheers
Jaron
Cheers
Jaron
Hi Jaron,
Not a problem.. Fitment should work out great and hopefully your problems are solved :)
Regards,
Sherwin
Hi Sherwin
Just wanted to let you know that i fit the lock bar last night, the whole process took about 30 mins and it solved the problem, it feels like im driving a new car.
Highly recommend this product to anyone experience hicas problems.
thanks
Jaron
Just to update all who are interested..
Hydraulic Blocking kits are on the way :D
I have decided to get 2 types made up..
Type 1 will be the "standard" blocking kit which blocks off the lines at the rear of the car..
Type 2 will the the blocking kit which basically blocks the reserviour and the rear outlet of the pump, allowing you to remove the complete HICAS system :3some:
Also an update on Lockbars..
More R32/S13/A31 Hicas Lockbars are in the process of being made :rofl:
There are 5 x R33/R34 Hicas Lockbars still available and more are being made with the Type A's :mad:
Regards,
Sherwin
Sherwin,i got my Lockbar,on the invoice it says 'suit R32' (which is what i need) but in your 2nd post you got me down in the R33 Lockbar section as paid & sent.can you just confirm that the invoice is correct.
Cheers
Aaron
p.s what parts are involved in the type 2 hicas block kit???....bungs?
Cheers
Aaron
Hi Aaron,
My appologies :thumbsup:
I have you on my paperwork as an R32 Lockbar, and I see that in the list I have you as an R33, I will fix this up right now >_<
The Blocking kits are;
Type 1 - Hydraulic Nuts and Bungs
Type 2 - Blocking Pipes, Copper washers, etc.
Instructions will be included in both kits :O
Regards,
Sherwin
Any left for an R33? PM me if so with details. Cheers.
There are currently 5 left for the R33 and R34s.
I have replied to all PM's :D
Regards,
Sherwin
Hi Everyone,
I just had my shocks/springs and a few bushes replaced and also all the hicas items pulled from my car and
replaced with Sherwin's Lockbar(which fits perfect).
Every other suspension place i went to would only fit the lock bar and rip the hicas wires.
Wholesale suspension on Third Ave At Blacktown NSW will fit Sherwin's Lockbar and remove all hicas
related items along with it for a very reasonable price.
Aaron
by the way my car feels like a go-kart now,its awesome!!!
i took some round-a-bouts and couldnt feel the crazy hicas at all,but did encounter some scrubbage which
will be fixed asap.
Edited by RSTME
Hi Everyone,
Aaron
will be fixed asap.
Hi Aaron,
Thanks for the update..
I am sure there are a few people near you who would be interested in that information :rofl:
Oh by the way, if anyone else from the other states, etc. have any other workshops they can recommend to fit these, please be my guest to post them up in here for other members to see :)
Regards,
Sherwin
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
