Hey
Just got my car on the road few weeks ago, It was such a nice day i thought i would take some pictures. (Sorry if they are to big)
Also a Massive thanks to Simon (FLYSLY) for lending me some tyres so i could get the rego :(
No worries!
Car looks bloody nice by the way
  • 3 weeks later...
  • Replies 369
Posted Images
hey guys
this is mine
have had her for just over a month now. still stock as a rock apart from cat back exhaust and GTT rims
mods for the future is:
type M front lip
Coilovers or a good spring and shock setup
18 or 19" rims with black spokes and poliched lip
new 3" high flow cat and front/dump pipe
GTR cooler
and that will be all
Edited by ashneel
Spotted nuR.spec's old red GTR on wellington rd turning into Monash Uni with a wrx
ye saw it also yesterday. looks farking hot. was displayed at the C4C cruise next to a rex and anotiher 32 i think
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
