Hey
Just got my car on the road few weeks ago, It was such a nice day i thought i would take some pictures. (Sorry if they are to big)
Also a Massive thanks to Simon (FLYSLY) for lending me some tyres so i could get the rego :(
No worries!
Car looks bloody nice by the way
  • 3 weeks later...
  • Replies 369
Posted Images
hey guys
this is mine
have had her for just over a month now. still stock as a rock apart from cat back exhaust and GTT rims
mods for the future is:
type M front lip
Coilovers or a good spring and shock setup
18 or 19" rims with black spokes and poliched lip
new 3" high flow cat and front/dump pipe
GTR cooler
and that will be all
Edited by ashneel
Spotted nuR.spec's old red GTR on wellington rd turning into Monash Uni with a wrx
ye saw it also yesterday. looks farking hot. was displayed at the C4C cruise next to a rex and anotiher 32 i think
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
