yo dude stencil ur licence plate number on there then there wont be any plates haha
Had thought of using my license plate, but as my mate had pointed out , Whats the point when the plate is 6" above it anyway? ha ha i cant not run a plate for fear of wrong attention.
if i can find my stecil ill bring it to the next autotest for ya mate
Cheers, but ill need it before that. Hoping to have the cooler on by weekend. Planning on making my own if i can be bothered now lol
standard s1 with the number plate area and below removed
So therea a very good chance that with my plate on, the logo will not be visible anyway?
Hopefully putting bumper back on tomorrow night. will know then i guess.
Hi!
Does anyone know whether a Greddy Spec-M Intercooler is any good or should I also go with a Hybrid, as I have seen these around on eBay etc. and was thinking of getting one for my R33 RB25DET?
http://www.modyourcar.com.au/product_info....roducts_id=5101
Thanks!
Pete
Edited by Peter
Hi!
Thanks!
Pete
You trying to take over my thread???? lol
For that question it might be better to start a seperate thread, that way people who have a Greddy cooler will see it, and they can post thier thoguhts. All i can tell you is i have just finished fitting my Hybrid cooler and it seemed pretty easy to fit, and it seems to work well.
Cheers
Brad
Cheers
Brad
easy to fit Brad? not from what i heard and saw lol. at least you finally got it on
Its a bit harder to fit than expected. Still just trying to trim the bumper up neatly. Hopefully should drive out of here tonight. I have bought the heavy duty tools in now
warned you youd need to go hacking the bumper i know it sounds ruff but a grinder really works well if its a plastic bumper the diamond disc just glides thru and you can be reasonably neat to
yea will go thru the bits off the skyline pile and see if i can track that stencil down for ya mate
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
