Just thought I'd get some expert opinion before ringing around.
I have a 89 R32 GTR with the common yellow Bilstein shocks that aren't really that well suited to Sydney roads, but now that I have moved back to canberra they are more livable.
The problem is when putting on some upper rear arms, it was discovered that one of the shocks has been broken for a long time (maybe even from when I got the car).
The thread on top of the shock has snapped off. what I want to know is,
1st, is it repairable and approx how much
2nd, would it be more cost effective just getting new shocks
Thanks for any help.
Cheers
Michael
https://www.sau.com.au/forums/topic/166669-reparing-shocks/
yep it's repairable. talk to bilstein in sydney. they have all the facilities to do it.
http://www.bilstein.com.au/
Thanks for that, alittle disappointed when I rang them up as they couldn't give me a rough estimate on how much it would cost even after describing the problem and said I had to bring it in for a quote during a weekday. Alittle bit of a hassle since work in Canberra. oh well.
Just wanted to know if it's going to cost $300-$400 to repair I'm better of buying a second hand set instead of repairing 1 shock.
https://www.sau.com.au/forums/topic/166669-reparing-shocks/#findComment-3087239
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
