Wheels are 18x9.5 work meister s1 2-piece, offset should be around +20, i had 265/40/18 michelin pilot sports all around n those were still fine and sat flushed. Also had 265/35/18 advan a048, kumho v70a and dunlop dz02g which all had no problems. The 275s that im looking at are Dunlop SP Sport series or Bridgestone Potenza series.
I'm running the same rims (Workmeister S1) in 18x10 +20 with 265 rubber and they j-u-s-t clear (had to flair the inner lips on the guards slightly). I guess the 275 on 18x9.5 would be around the same.
i have to be honest here. i can't see why you want 275 tyres in the first place? 265 is massive. and 255 is ample. especially on a 9.5inch rim a 275 will probably handle worse than a good 255 and the 275 will be heavier and more expensive.
no one can tell you for certain if it will fit or not. so many things will affect that. offset of your wheels? ride heigh of your car? castor setting? front camber? rear camber? height of bumptops? only way to find out is buy and try.
What he said! 275's would be craptacular on 9.5s.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
