hey guys
i picked up an r33 gtst s1. it had an audible noise (a whine) coming from the timing belt. you could only hear it when under the bonnet. i took it to local mechanic.
we took it apart and inspected the idler / tensioner bearings. these seemed to spin flawlessly in our hands. to quickly test, we put back on the timing belt, no other belts, no cover, etc, and started it. no noise. using a stethoscope we listened to idler / tensioner, no trace of the original sound. we suspected over-tightened belt.
all other belts were replaced and put it back together. turned it on, no noise for a while, but as soon as it warmed up the noise was there. the noise is always there now, regardless of being hot / cold, and mechanic still thinks its coming from the idler / tensioner.
should i go through all the hassle of pulling out the radiator, belts, crank pulley, timing belt, to replace the idler / tensioner? i'm concerned that the noise is not coming from them and i'll just be wasting my time, and money
is there any other avenue that i could investigate , perhaps someone has had a similar problem before?
cheers
https://www.sau.com.au/forums/topic/167048-noise-from-timing-belt-area/
you could replace the drive belts (fan belt etc). these are relatively inexpensive and if its a fresh import, its most likely they are worn anyway.
If this fixes it then you've saved yourself a lot of time and effort, and if not, well now you know they are new and you've made progress towards nailing the problem :P
hey mate i had a similar problem after replacing timing belt with a non gen item it was like the belt was too thick but it made a graunching type noise that increased frequency as revs climbed and i did the same thing took all belts off checked all bearings idlers for drive belts a/c bearings started engine with no belts on at all, noise was definetely coming from timing belt.
I sent the belt back and got a genuine item (which worked out $30 cheaper, got better than trade though) fit it all up then it was fine no matter how much tension i put on or took off the belt, weird huh???? always use genuine eh. to me it sounded like the teeth on the non gen belt were sort of too big for the cam and crank pulleys. i am not 100% sure of the exact problem but all good now.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
