  • Replies 153
Thant would work, but it would only filter fumes on heavy throttle, during light thottle fumes would enter the plenum (although its not a huge issue but why not prevent that too if you can, I'm sure it would prevent the sparkplugs fouling a bit.)
According to a pic of a redtop RB20 I have infront of me, the system is how you drew it but there is no hose connecting the 2 rocker cover pipe connections. For best results you would hook it up the same way as my drawing but the brown hose would connect to the right rocker cover and the blue hose would connect to left rocker cover.
Air is drawn from the air intake pipe before the turbo.
From a legal point, if you block the line from the plenum to the rocker cover, it does not make the car illegal, as the fumes are still being plumbed (via catch can if you have it) back into the plenum through the air intake and not just being vented.
The air drawn from the intake does not neccesarily make it into the main body of the rocker cover because the two breather connections are joined.
Also, i'm in the situation where I need my car engineered, AFAIK one of the stipulations is that all emissions equipment is retained.
OK, dont do it then.
But just to clear it up. The breathers are joined, but in the stock form, the line from the rocker cover to the plenum comes out of the side of the rocker cover, not from the connections on top of the rocker cover.
If you have a close look at the engine, it will become painfully obvious.
Just so you understand, PCV is positive CRANKCASE ventillation, there is a one way valve to stop air being forced from the plenum into the rocker cover, ie, prevent a boost leak, BUT it doesnt matter what path the gasses from the crank case take, as long as they go through the induction system and get burnt in the cylinders. This is only done, as previously mentioned, to appease emissions requirements.
Originally posted by Steve
Browny, if you do it that way, air will just follow the path of least resistance, so you wouldnt get clean air going through the rocker cover - not that I think its necesarry - so it would be easier to just block off the line to the plenum as adam32 suggests.
Do not block off the PVC valve. How many times do I have to say it. The way you brownie drew the pic is good. If you block it off, all fumes will go through the intercooler and turbo at all times as it is the ONLY path. There will always be some oil left in the gasses even after it has been filtered so it will block your intercooler over time. With the PCV system in place the filtered fumes will go straight into the plenum and not through the IC around 98% of the time. The filtered fumes will only go through the IC under heavy throttle with the valve in place. This has nothing to do with crankcase scavenging. It just makes logical sense and to dissagree would just be down right subborn.
The silver RB20 is one of a minority of engines that does not SUCK the fumes out of the rocker cover. This is done to reduce oil consumption in a highly stressed engine. The usual way of doing it sucks most of the oil fumes out before they can condense back into a liquid. If it were me I would revert it back to the normal system by removing the hose that connects the rocker covers together.
Just think about what would happen inside the crank case. There are oil fumes in there, and unless your rings make a 100% seal there will be raw fuel and combustion by products in there aswell. It only makes sense that when the oil fumes recondense, they will mix will all that other nasty crap and end up in your sump. Having the PCV system hooked up the way it was originaly designed sucks a lot of this crap out before it ends up mixing with the oil. I would rather have this crap sucked out before it contaminates the oil.
And for the 6th time. Even in the sliver RB20's case, THE PCV VALVE WILL DO NOTHING FOR EMMSIONS. Looks at Brownies pic and pretend the PCV valve was blocked off. The fumes would make there way out to the intake and get sucked back into the engine anyway. Hopefully we can all see how this would happen. Understanding that, you might ask why its there in the first place. That answer lies in my first paragraph! To stop 98% of the oil vapours going through the intercooler and dreamatically reducing its thermal effeciancy over time.
Brownie, just do it the way you drew it. It looks at least you understand about the fumes through the IC thing. But if you would also like the benefits of active crankcase scavenging (how ever minute they might, or might not be) Hook it the way I showed. Theres a bit less plumbing too. You just need to find some decent one way valves.
Heres a modified version for a RB20.
Dennis, you are pretty paranoid about fumes going into the cooler. I dont know how you could say 98% of the time the fumes go directly into the plenum, unless your car is a lag monster and you rarely hit boost. I cannot drive my car with out going on boost, even driving sedately, just keeping up with traffic - if I am accellerating at over 2k rpm, she boosts. Perhaps you have a restictive exhaust system?
The amount of oil mixed with the crank case gasses is pretty minor when not on boost, if at all. This is why its only really necessary to fit a catch can when you wind the boost up, because otherwise there is insignificant amounts of oil going through the system - in a healthy engine anyways.
Do not block off the PCV valve. How many times do I have to say it.
you only have to say it once - its your opinion, my opinion differs. Perhaps if you could give examples of actual problems you have encountered it would add more weight to your statement. But at the end of the day I wont tell you what you have to think, dont try and tell me what I have to.
I listen, I evaluate, I compare statements to my own personal experience - and it takes alot more that a repeating a statement over and over, with out qualification to make me change my mind.
I am really sorry if this upsets you, as you do seem to be getting a little upset?
Agreed the pcv valve does nothing for emissions, I really dont know what your getting all upset about there. All I was getting at is that it is illegal to vent crankcase gasses to atmo. Agsin you seem to be getting a bit upset? Why?
Na its cool man, im not upset or paranoid. 98% is just a bullshit figure I pulled out of my arse. But you can see that it is a large % of the time. It could even be more that 98% if the car is used mainly on the HWY. I'm just sick of saying the same shit over and over again. The thread was about PCV systems so I just added my opinion. The reason I raved for so long was that I felt my valid point had been ignored or missunderstood. I couldn't care if people dissagree with me as long as they have understood what my point was first, and tell my why their particular way is better (which no-one including you has done in this thread as of yet). I am not stubborly held in my ways, a simple explination of why any given method is better will change my mind.
I think you have finaly understood what I was trying to say, but seriousy... Why would you purposly want fumes to (potentialy) clog up the cooler when it is just as easy to have them go staight down the plemum? Given the fact that this whole thread is based around preventing blowby related probs, I would like to here what the benefits would be, by intentialy passing extra fumes through the intercooler for no apparent reason. I will be VERY interested to here you reply. It seems very 1 step forward and 2 steps back to me is all. I hate to see people spend money and time on mods that might have negative effects. All it takes is a walk down to the importer to see how much crap ends up in a second hand cooler, even on stock systems which vent to the plenum.
And also, now that you have accepted that the PCV does nothing for emmisions, would you please tell me what you think it is there for?
No hard feelings :O
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
