Hi guys have the following for sale, pics up soon! Parts are from my Rb25/30 engine to suit GTR/GTS4 which produced 270rwkw on just over 1bar boost. Engine has done 8,000km since full rebuild.
Dyno graph
RB25/30 3L TWIN CAM TURBO ENGINE COMPLETE MINUS EXHAUST MANIFOLD AND INLET PLENUM ALL THE REST IS THERE COMES WITH 4WD DIFF RUNNING 4.375:1 RATIO, SUMP AND MODIFIED EXTERNAL OIL PICKUP.
FINAL PRICE DROP!!!
$3000
post-31991-1180457127_thumb.jpgpost-31991-1180457217_thumb.jpgpost-31991-1180457308_thumb.jpgpost-31991-1180457336_thumb.jpg
post-31991-1180457264_thumb.jpgpost-31991-1180457391_thumb.jpgpost-31991-1180457365_thumb.jpg
OR WILL SEPARATE
RARE R32 RB25 Non-VCT RECONDITIONED HEAD NEW VALVE SPRINGS COMPLETE $1100
RB30 SERIES 2 REBULT BOTTOM END WITH 4WD SUMP MODS AND EXTERNAL OIL PICKUP $2200
Edited by FOOLBOOST
  • Replies 44
the sard injectors that you have
are they side feed for and would they be suitable for a r33 head
How much for the plenum?
Sard injectors are top feed and suit R32 rb25 head, im taking offers over $800 for plenum with borred out tb, modified accelerator cable, coolant apparatus, top radiator hose and aac valve
Where did you get your plenum from an it would most likely only fit the rb25 r32 head? or would this bolt to an r33 head as well
Plenum was purchased from Abarth motors, and is to suit R32 rb25 head as stated above
PRICE UPDATE
RB25 HEAD / RB30 BLOCK ENGINE COMPLETE MINUS INLET AND EXHAUST MANFIOLDS, ENGINE COMES COMPLETE WITH BELTS, ALTERNATOR CAM COVERS, COIL PACKS, IGNITOR, NGK IRIDIUM PLUGS ETC WILL ALSO CHUCK IN LOOM
$3500
Afm now comes with plug as i found it :P
Also new deal with the external gate comes with adaptor to suit stock manifold whilst also enabling use of a gt3040 or gt3540 comes with dump/front too with flex, copper gasket and 02 sensor, pics attached $800.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
