Just installed monday.. anyway heard this rattle/scraping noise on the way home from the back of the car, thinking maybe the top bolts were bit loose or something for the coilover, took the wheel off and saw this lovely sight:
The 1st pic is of the coilover with a nice flat spot (from the wheel)
The 2nd pic is of the wheel with this nice shiny line going alll the way around.
Anyway running 255's on the rear, had no problems with the factory shocks + 2" lowered king springs.
who knows how to fix before my new coils are stripped :)(...besides getting new rims with different offsets)
thanks in advance! - right section this time!
How low is it now?
Id suggest an adjustable upper arm or bushes to correct the usual rear camber issue when the car is lowered and bring camber back into the <1 degree range. Then look at a 2mm slip on spacer if that doesn't fix it
thanks! yer i was thinking something like that today.. u know where i can get a slip spacer? i was thinking washers lol..
car is 970mm from nismo rear bar to ground. i'd plan to raise it only a little, anyway theres going to be more camber shortly :D hehe yay for drift :D
970mm??!!! :D
Firstly, What car, what width and offset wheels are u running?
Spacers will probably fix ur coil rubbing problem but unless we know what width and offset ur running, you might end up rubbing the guards after fitting spacers?? Might have to get a new wheel in the end..
car is 970mm from nismo rear bar to ground. i'd plan to raise it only a little, anyway theres going to be more camber shortly :teehee: hehe yay for drift :P
problem fixed.. washers = 2mm = fixed.. until i get a proper spacer.
LMFAO.... :laughing-smiley-014:
his next topic will be how to fix broken wheel studs after loosing rear wheels washes= stupid and dangerous
Edited by mid life crisis
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
