Guys,
just a quick question to those who have installed these units.
As the manual is in japanese i am not sure but i see diagrams of the boost control soliniod in series with the standard boost solinoid which does not seem right. Had advise to remove the standard and replace with the Apexi which seems simple enough. Yet to try it out but will do thursday i hope.
One more point is it possible to change the reading on the commander from mmhg to bar as a readout.
thanks.
https://www.sau.com.au/forums/topic/167896-power-fc-boost-controler/
Hey mate, I've just installed one last week.
http://www.skylinesaustralia.com/forums/in...3&hl=birnie
The pictures aren't showing but i can repost em later when i get home for you.
They show the wiring too which isn't too hard.
Yeah, +ve pressure in bar
-ve in mmhg
That's the same as my mechanical Blitz boost gauge.
Pressure might not have the same physical characteristics in negative pressure and therefor not messured in 'bar' as i believe even the PSI gauges have hhmg as -ve pressure, or vacuum (could be wrong, but once you've got complete vacuum ie space, you can't suck anymore out so it must be approaching a limit with the more vacuum reading you get, but pressure can keep increasing???)
Birnie
The hose with the restrictor???
There is a clear filter if that's what you mean.
I was gong to put that on the sensor hose but it doesn't fit....didn't use it at all.
Anyway....some pics here : http://people.aapt.net.au/~jason1973/Skyline/
LOL i was talking about the hose from the standard boost controler with the restrictor in it ( has yellow band around it ) does that go to the waste gates or is it from the manifold..
Thanks for the pics mate they are a great help.
regards
Edited by tacker
I ditched the old tube and used what came with the unit.
So no restrictor at all.
Also, pressure feed from the intercooler piping went into the 'NO' hole on the new solenoid, and continued out the 'COM' hole which went to the wastgate.
  • 8 months later...
this bloody thing is still not working went to lift boost to 1.2 bar to find it has just been using the actuator spring.
Could the harness from the ecu to the boost control solinoid be damaged, guess i will need to check. Tried to run at .8 bar only to have it go into boost cut no matter what value i entered in the duty cycle.
GRRRRRRR
if you find its going into boost cut no matter what, ie: its spiking way over target boost then check the vac lines etc
if they are backwards it might not control boost at all and just never open, hence unlimited boost, hence it spiking way past target regardless of duty
or the wiring is wrong., its simply ground and positive power, if they are wrong the solenoid wont work
Hi Paul,
Ok what i have done is run a whole new line from the COM port on the solinoid valve over the engine into a tee piece, then to both to both waste gate actuators. I then plugged the old exsisting vac lines to the actuators with a bolt and clamp.
I have then used compressed air to determine which of the exsisting vac lines connected to the original factory boost controller are connected to where, ie before the turbos or after. I then connected the vac line plumbed in after the turbos to the NO port of the solinoid valve, And again plugged the other exsisting line now not used.
The wiring, i used the exsisting ( original nissan ) boost controller harness, and then plugged the new cable from the Apexi solinoid valve into the exsisting plug that was connected to the original nissan boost controller, and therefore should be connected to Power FC through this original harness.
bugga need coffee now after typing so much :-)
There is no spiking as such it sits rock steady on 1.15 bar if i have the boost limit on the hand controller set to 1.2 bar, we proved this time after time on the dyno last weekend. If we removed the vac hose to waste gate actuators and left it open to free air then it would spike, but wouldnt move from 1.15 bar while connected to the COM port on the Apexi solinoid valve. Even if we connected either of the older exsisting lines from the factory boost controller on the NO port it made no difference, hence why i dont think the Apexi solinoid valve is getting a signal from the ECU, or the valve is not functioning when it gets a signal.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
