Guys,
just a quick question to those who have installed these units.
As the manual is in japanese i am not sure but i see diagrams of the boost control soliniod in series with the standard boost solinoid which does not seem right. Had advise to remove the standard and replace with the Apexi which seems simple enough. Yet to try it out but will do thursday i hope.
One more point is it possible to change the reading on the commander from mmhg to bar as a readout.
thanks.
https://www.sau.com.au/forums/topic/167896-power-fc-boost-controler/
Hey mate, I've just installed one last week.
http://www.skylinesaustralia.com/forums/in...3&hl=birnie
The pictures aren't showing but i can repost em later when i get home for you.
They show the wiring too which isn't too hard.
Yeah, +ve pressure in bar
-ve in mmhg
That's the same as my mechanical Blitz boost gauge.
Pressure might not have the same physical characteristics in negative pressure and therefor not messured in 'bar' as i believe even the PSI gauges have hhmg as -ve pressure, or vacuum (could be wrong, but once you've got complete vacuum ie space, you can't suck anymore out so it must be approaching a limit with the more vacuum reading you get, but pressure can keep increasing???)
Birnie
The hose with the restrictor???
There is a clear filter if that's what you mean.
I was gong to put that on the sensor hose but it doesn't fit....didn't use it at all.
Anyway....some pics here : http://people.aapt.net.au/~jason1973/Skyline/
LOL i was talking about the hose from the standard boost controler with the restrictor in it ( has yellow band around it ) does that go to the waste gates or is it from the manifold..
Thanks for the pics mate they are a great help.
regards
Edited by tacker
I ditched the old tube and used what came with the unit.
So no restrictor at all.
Also, pressure feed from the intercooler piping went into the 'NO' hole on the new solenoid, and continued out the 'COM' hole which went to the wastgate.
  • 8 months later...
this bloody thing is still not working went to lift boost to 1.2 bar to find it has just been using the actuator spring.
Could the harness from the ecu to the boost control solinoid be damaged, guess i will need to check. Tried to run at .8 bar only to have it go into boost cut no matter what value i entered in the duty cycle.
GRRRRRRR
if you find its going into boost cut no matter what, ie: its spiking way over target boost then check the vac lines etc
if they are backwards it might not control boost at all and just never open, hence unlimited boost, hence it spiking way past target regardless of duty
or the wiring is wrong., its simply ground and positive power, if they are wrong the solenoid wont work
Hi Paul,
Ok what i have done is run a whole new line from the COM port on the solinoid valve over the engine into a tee piece, then to both to both waste gate actuators. I then plugged the old exsisting vac lines to the actuators with a bolt and clamp.
I have then used compressed air to determine which of the exsisting vac lines connected to the original factory boost controller are connected to where, ie before the turbos or after. I then connected the vac line plumbed in after the turbos to the NO port of the solinoid valve, And again plugged the other exsisting line now not used.
The wiring, i used the exsisting ( original nissan ) boost controller harness, and then plugged the new cable from the Apexi solinoid valve into the exsisting plug that was connected to the original nissan boost controller, and therefore should be connected to Power FC through this original harness.
bugga need coffee now after typing so much :-)
There is no spiking as such it sits rock steady on 1.15 bar if i have the boost limit on the hand controller set to 1.2 bar, we proved this time after time on the dyno last weekend. If we removed the vac hose to waste gate actuators and left it open to free air then it would spike, but wouldnt move from 1.15 bar while connected to the COM port on the Apexi solinoid valve. Even if we connected either of the older exsisting lines from the factory boost controller on the NO port it made no difference, hence why i dont think the Apexi solinoid valve is getting a signal from the ECU, or the valve is not functioning when it gets a signal.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
