hey guys , just wondering those of you who have a 34 what type of turbos are you running? as im looking to up the cheaply high flowed turbo i have (stock high flowed) as i dont want to go down the path of a aftermarket computer yet .. any suggestions would be good !
Reason for keeping it stock looking - i want to re-use the turbo heatsheild as cops these days are a pain !! rather not want to get defected
Cheers
https://www.sau.com.au/forums/topic/168055-turbo-setup-on-r34-gt-t/
I was looking at upgrading my turbo to a Apexi AX53B70 as it's low mount, internal gated and apexi said "The AX53B70 turbine power output is around 600HP depending upon application" it uses the ihi catridge so can still be rebuilt with apexi dead... another choice would be a GT-RS which would keep everything looking stock as it comes in a bolt on kit, depends how much you wana spend? wont get full potential out of teh turbo with a stock ecu unless remaped.
Btw my turbo is stock
There is 3 AX53B70s the p21 is used as a twin set up on GTRs, the P25 is rated to 380hp, I have this it is really responsive and made 245rwkw at 14psi on my car, so there is a bit more in it yet and the P28 which is a big high mount job thats the 600hp one
The P25 would be a good choice Vish I love mine but you may have trouble getting one. Apexi turbos are rare these days! I know I have been unable to get my hands on a RX6 kit, websites say they have them but when you try to order they say they are out of stock
ah cool gives me some ideas on them rite now im running a gcg stage 1 high flow which was at that time cheaper since i was on a budget .. spool up is great power wise it lacks mid to high end... hence upgrading..
Its hard to buy them brand new as they are a discontinued item, i have seen a couple go through yahoo auctions for around $800 second hand
Thanks guy i tried searcing a few places without much luck not many people seem to know about them .. any one knows anything about a stage 2 highflow or slide overmax ?
Seriously mate their isn't much point in upgrading the turbo (which is already decent) until you get the best out of it by way of after market management. That said the slide max high flow is a good thing, I have seen one make 200rwkw at 5psi
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
