alright...so i go to get a wheel alignment, and after spending 2 minutes telling the apprentice how to start the car so he can drive up onto the car lift, they get started...and then tell me they have no data for stagea and can't do it..they will order the floppy disks (old machine i guess) and have data in a week... but NISSAN refused to help me (obviously..they dont have FAST JP and they don't give a rats arse) and i couldn't find SK's number. I told them that "front track width should be same as GTR33 as i think the front swaybar fits, but otherwise i have little idea (and in retrospect...i believe i am wrong in even that little detail...because didn't Grant try and the gtr33 sway ddn't fit...right?)"
SO...
Gary, Grant...and anyone else who has a clue... WHAT IS THE DATA TO GET A WHEEL ALIGNMENT???
Castor? Camber? etc etc... (i don't knwowhat they need to know.)
suspension is as stock as a ducks guts...
can't wait to get new gear from group buy after tax time :wave:... hehehehehe
bloody TSV wheel alignment boys :D:laugh:
CHeers.
https://www.sau.com.au/forums/topic/168258-wheel-alignment/
link edited as Im a fool
some info
fyi: Ive had gary's group buy on my car for over a year now, including R34 mags and new tyres fitted 14months ago. havent had a wheel alignment and tyres are wearing perfectly.
got to fit the front adj bushes and align it all tho.............. now the bike is sold got some cash to get it done.
want to grab a shift kit too =)
https://www.sau.com.au/forums/topic/168258-wheel-alignment/#findComment-3111109
fwiw
for touge my alignment is
Front
-1.5* camber
.5* toe in
stock caster
rear
.5* toe in
-.75* camber
thats all i had adjusted
i need to buy traction rods for the rear and tension for the front so i can finish my suspension
but these numbers are only an initial alignemnt to what i had on my 180.
i need to get it on the track and find out what i need to tweek...im sure the rear toe is gonna wanna go a tad in for a better initiation for my drifts....but it hinders my high speed stability..so we shall see.
BTW GTR33 front fits
S14 rear fits
sway bar wise
buttt since sydneykid hasnt spoken yet, and im sure he will contradict everything ive told you so far
If you want an alignment that is in the middle of comfort and performance oriented
GO stock camber all around.
in the front tell them to tow it in a half a degree. you will get a more responsive turn in on your turns.
but that is ONLY my experience, and is by no way a go by rule.
i tend to like it more.
https://www.sau.com.au/forums/topic/168258-wheel-alignment/#findComment-3111333
fwiw
Front
-1.5* camber
.5* toe in
stock caster
rear
.5* toe in
-.75* camber
S14 rear fits
sway bar wise
righto....read all the sugested threads...great guys and thanks again for saving an idiot :domokun:
from what i have read-stock camber can be pretty disgusting..as i am getting some wear on the inside of the tire - and other wheel alignmnet readouts have readings around 2degrees40 - i have been suggested to that i should aim for 1 degree.
https://www.sau.com.au/forums/topic/168258-wheel-alignment/#findComment-3111415
Our Wheel Alignment machine at work has data for all Stagea's. It lists a suggested Min an Max for each adjustment. Eg - Camber may be Min - 0 an Max maybe -2 . Does anyone want me to get any thing imparticular? Its got 4 an 2 wheel drives and also has the 260.
https://www.sau.com.au/forums/topic/168258-wheel-alignment/#findComment-3111629
depends
whatcha wanna do with your car?
do you have any adjustable links?
once i get all my links, all my settings will be just out of factory adjustable range.
i picked up some Cusco tension rods this evening....rear traction rods are all it takes and im done!
https://www.sau.com.au/forums/topic/168258-wheel-alignment/#findComment-3111706
righto....read all the sugested threads...great guys and thanks again for saving an idiot :D
camber doesn't wear tires
Toe does
I ran -3* camber on my 180 with -.25* toe and had no abnormal tire wear.
they wont last 40,000 miles, but they last 6-7 months.....which by they they are burned off anyways....but thats just me...again lol
https://www.sau.com.au/forums/topic/168258-wheel-alignment/#findComment-3111708
SK says its in the group buy thread. If you cant find it I have the figures.
I've just had a f**king horendous time getting a tie rod end. By the time I add up time effort and money it must have cost me near a grand. Absolutely NO bullshit.
Anyway today the Stag is all back to kosha. I aged so much I' thinking of changeing my name to, at least 72yo.LOL
IncidentlyI have a spare tie rod end now so if anyone is stuck, give me a buzz.
https://www.sau.com.au/forums/topic/168258-wheel-alignment/#findComment-3111738
thanks guys... i just really eeded some target figures for a wheel alignment place here in Townsville... It was a quick check cause i popped a tyre bead and went off the road on Thursday night and wantwed an alignment quick smart...but it's driving straight..there isn't any visual damage to rim/tyre or arms... it all seems ok.. getting it done on wednesday now.. but at least i have some target figures now. Thank you very much :)
Will have SK's kit as soon as i get my tax back :yes:
https://www.sau.com.au/forums/topic/168258-wheel-alignment/#findComment-3114948
Stageas, standard, have toe adjustment front and rear and small camber adjustment on the rear only. So that's all they can adjust, giving you front caster and camber figures that they can't achieve is a waste of time.
I assume it's an RS4, so 4wd alignment figures are the go.
Front toe, out 1 mm each side, we never measure toe in degrees in Australia, it's always mm (or inches for the old guys).
Rear camber, the standard adjusters are good for 0.25 degrees. So the best you can usually achieve is to get them somewhat the same. The less negative camber the better.
Rear toe, I find that RS4's (with standard suspension) understeer pretty much all the time. So I run a little toe out, around 2 mm a side, which helps with the turn in.
When you get some adjustment facilities for the front caster and camber and more adjustment range in the rear camber, the Group Buy recommended settings will be possible.
:D cheers :)
https://www.sau.com.au/forums/topic/168258-wheel-alignment/#findComment-3117343
'spirited' drive up a mountain - musn't have had enough pressure in the leading outside tyre - body roll - 1700kgs onto passenger front tyre whilst coming off braking (so weight was already on the front wheels) - and *pop* - chris does the 'HOLY CRAP............................."
least to say, I shall avoid the 'spirited driving' till i have SK's kit, a wheel alignment and checking my tire pressure next time
like i said...no real damage aprat from ahving to popthe tyre back on down the servo with 40+psi and some paint cracking on the front spoiler under flex...
my sidewalls on the 16's are competing with fairy floss in a plasticity competition - espescially under body roll......*yuk*
Sydney Kid... I lurves you....
Edited by captinsane
https://www.sau.com.au/forums/topic/168258-wheel-alignment/#findComment-3117579
lol, are your wheels ok?!!
Im glad everything turned out ok though, im sure that was a scary episode. lol
https://www.sau.com.au/forums/topic/168258-wheel-alignment/#findComment-3117597
wheels are fine remarkably... a little more scrubbing but there was a ton on there when i first got them from a previous owner so i am not all that worried... Hasn't lost any tyre pressure over the last 2 days and no visible damage otherwise :D
Wheover had it before me even was complacent enough to let the tyre balancing guy put weights on the outside of the mags :P *yuk*
I expected to get out of the car and see power steering arms broken, tie rods gone and wheels poking away from the body at 90 degrees to each other... I was well overjoyed to see them pointing in the same direction and the inside of the wheel still on the rims... >_<
https://www.sau.com.au/forums/topic/168258-wheel-alignment/#findComment-3118424
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
