Any one have one laying around, i need one to pull the plug off nad make an interface between a motec M48 and the existing wiring, so i can change between the motec and the OEM ECU.
I have access to a M48 and just want to play around....
https://www.sau.com.au/forums/topic/16832-clapped-out-r33-ecu/
thanks anyway, im sure someone has a clapped out one laying around, like i said, i want to make an interface so i can pull out mine and plug in the motec, i have access to that and a dyno so i just want to play around.....
C'mon guys, surely there is one laying around, once i get the ignition expander, 3 bar map sensor and wide band lambda sensor ill be set to go, just need to make this interface...
Got my little 1.6 litre to 80 Kw at 5000 rpm yesterday (engine dyno). Dont want to push it till i have my fuel maps ok above that, but hitting just over 8 PSI boost with .84 lambda at 5000.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
