Put my motor back in my gtr last weekend after a comlete rebuild. I have now done 500 k's and have come across a problem. There are drops of oil forming from the bottom of the bellhousing which im guess is most likely going to be the rear main leaking. Now heres the problem, when i sent the block and crank etc for machining they machined the surface where the rear main seals. He said that there should still be plenty of meat for the seal. When i re assembeled the motor i found that the seal felt very lose over the crank and i thought to my self this is gonna leak for sure, but anyway i took the risk and put it back in the car only to find that it is leaking :D Its not a huge leak but is only going to get worse once i wound the boost up and the crank case pressures increased.
So now i have been told that i will most likely need to fit a speedy sleeve to the crank. Has anyone ever come across this and had to fit one? Also do they make them to fit an rb26 crank and where can they be bought from? Im unsure how much has been machined off the crank either.
Any help would be good, Cheers
Edited by OFENSV
https://www.sau.com.au/forums/topic/168327-rb26-rear-main-oil-leak/
If he has ground it undersize, it will need a sleeve for sure to seal up.
Why the hell did he decide to machine that part for, if it wasn't hugely scored to begin with there is no need a new seal would have worked fine.
Its not gunna be cheap a sleeve that large in diameter.
Apparently from what i'm told, what they typically do now is metal spray the crank and then machine it back to factory measurements to save the sleeving process. To late now its all assembled though i guess...
Do a google search, most bearing shops carry the Speedi product range.
They are rather simple to install, choosing the correct size on is the hardest part, you have to measure exactly.
http://www.chicago-rawhide.com.au/Products/speedisleeve.htm
That might give an idea.
  • 16 years later...
Hey, not sure if you are still active on here, but I am chasing the same leak. Its a slow drip from the bell housing. Can't figure out where its coming from. Did it end up being the rear main seal?
  • 5 months later...
Well I am also keen to know what happened in the end from this thread or even just to hear what you ended up discovering @Kevboost7?? I also have just put the engine back in my R32 after a rebuild and I have a large amount of oil leaking from nowhere very obvious at all and am worried about my rear oil seal as well as can't find any other leaks so far.. Oil seems to keep dripping from the bottom of the bellhousing even after I have cleaned and wiped up all of the oil mess after the previous spirited drive and I haven't even driven it again since..! That makes me feel even more that it is still just slowly running down from the higher rear main seal because so much oil is coming out...
@Milhouse Sorry to hear that brother. I never got to the bottom of mine, although i didn't have a large amount of oil like you described. I just wipe it up as best as i can everytime i'm under the car and if i ever have to remove the engine, then i'd find the root cause of this leak.
It sucks that you just had your engine out though.
  • Like 1
Put some UV dye in the oil and see where it's coming from. It could be a lot of things like a valve cover leak at a hard to spot corner.
  • 4 weeks later...
Yeah thanks never thought of doing that before so might give it a go. Got the intake manifold off at the moment looking but nothing there yet either. Have a rear head oil drain which I thought maybe leaking for some reason but doesn’t look like… 😕
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
