  • Replies 184
fatz, that would be awsome if I could get a ride... I dont weigh much so I wont slow you down. im not really keen on just jumping straight in the deep end so if I could see what its like as a passenger first it would help...
Should have turbo fixed by then... so we have already:
Majanal
Kel
Duncan
Silver
Red
Roy
Akira
Prank
Carlo
Kinks (50/50)
Benm (special spot reserved for you mate... try for the day off!)
Talej (To be convinced on Monday the 9th June)
Talej,
Like Silver said... tis an experience you will never forget... and just look what happened to Carlo... gave him a very small nudge (I think it was not even that) and now he is signing up for them eveywhere he can!!! As for safety if that is one of your issues then rest assured... people are very carefull as all stand to loose alot if they are stupid. We run through basic safety stuff and some basic track rules before getting on the track. The day is professionally run and not often to problems occur as long as things are prepared properly and you drive within yours and the cars limits.
I'm sure if you come along and introduce yourself to me (or any of the guys) they will take you for a few laps... tis not very often we do a lap without a passenger.
Hope to see you there,
Dan.
if i end up dropping out tomorrow due to the cracked cv boot, i will come to this one for sure.. (providing nothing goes all fu(ked in my old shitbox... :) )
but if i run tomorrow i don't think i would be financially recovered in one month ...
Yup awesome !
If tomorrow goes well than im in for sure (havent asked for a day off in 2 years, now I know why :P)
Guys,
I spoke to Tracy today and the deposit for track days will now have to be $100 and due NO LATER then 2 weeks before the day. I will then transfer the cash into Motoconcepts account and you will have to pay the balance on the day.
How ever I do have 15 spots set aside for this day... so let me know guys... ASAP!
Dan.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
