this intake pipe definately fits a standard turbo and standard afm or a Z32 afm as most of you are aware they are exactly the same size.
The plumb back pipe has to be modified a little bit, as the nozel on the intake pipe is in a slightly different position, but its easy done.
and also you just have to run a blow by hose from your left tappet cover to the nozel shown in my second pic
piece of piss, and looks tidier and no need to worry about the rubber hose suckin in, and a nice induction noise
Hey every im new to this site so i dont no wat im doin :laugh: jus wana say hey n introduce my self... tryin 2 make sum frnds on here so jus n e 1 msg me or n e thin 2 introduce urself :(
thankx heeps xo
i didnt end up getting pics connected up unfortunately. If i did they would of been the first pics up, cause it would of shown how tidy it looks
and how easy it is to install.
Its more time consuming getting the stupid rubber intake off
for this apexi intake pipe that comes with both silicon hoses , lowest i will go is 150 including postage at the moment, as i have interested ppl from other sites.
this still for sale. what area of brisbane you in? also what other parts you got for sale at the moment - i saw you had a dump for sale not long ago too right?
still have the dump , turbo, oil line and a standard manifold all to go,
(turbo is on ebay)
the intake pipe has gone unfortunately, but the guy hasnt replied back in two days, after being sold, so see what happens
let us knw if ya interested in the other parts
yeah i am in brisbane westside.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
