hi all
my car had been lowered when i bought it
im gonna put the normal suspention to get enought ground clearearance...
the problem is my mechanic said i shouldnt be change the suspension because i got mad suspention..
cant remember the brand but he said it worth around $3000.... anyway i dont wanna drive it around without
mad bodykits on... i prefer better looks than performance... anyway does anyone know good brand of suspention on R34 GTT? doenst have to be too good.. im talking about little bit better than standard suspention.. i prefer adjustable.... too many things guys... sorry..
cheers
paul
just adding one thing..
mine is fixed but if i change spring would the height of suspention can go up?
cheers
Edited by tyaos
https://www.sau.com.au/forums/topic/168686-recomend-for-suspention-on-r34-gtt/
If you have suspension worth 3K I would assume it has some form of height adjustment?? More than likely you may already have height adjustable coilovers in it? Take a pic and show us so we can try and identify what you have...
hi!
my mechanic said its fixed one not adjustable....
i cant remember the name of it but ill ask him and post it here..
and i heard that if i just change springs of suspension, i can get any height i want.... is that right?
or if i want to change height, do i have to change whole suspension???????
cheers man!!!!
It might still be height adjustable, you just need a machinist to etch a new groove and move the circlip up/down. That's what I had done to my nismo/bilstein coilovers.
i checked the name of my suspension.. its bilstein... and HKS springs... not sure its adustable... are there all bilstein are adjustable? i changed my wheels to 235/35/19 front 265/30/19 on the back... the height seems gone up a bit...
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
