I am organising a movie night to go see the Transformers movie (http://www.transformersmovie.com/) at the Yatala Drive-Ins (link). There is a Candy Bar on site however you able to take your own food & drinks.
This invitation is open to all and will be posted on www.sauqld.com, www.clubhighrollers.com & ricerockets.invisionplus.net
When:
Friday June 29, 2007
Cost:
Adult $13
Seniors $10
Child $7
Meet Point:
BP yatala out the back around 6:15pm and then head to drive in at 6:30pm sharp. Feel free to head straight to the Drive-in.
Please register your interested in attending this event here
https://www.sau.com.au/forums/topic/168894-drive-in-movie-night/
  • Replies 40
Posted Images
keh??
i know the mounds get steep if thats what you mean lol
yeah from a side view it looks like this:
_/`\_/`\_/`\_/`\_/`\_ (excuse bad image but i cbf drawing)
i bottomed out badly last time (might have something to do with the push start i needed but i wont go into that)
drained your battery...lol
yeah was on its way out though - have a new one now so as long as i remember to unplug the sub i should be ok :huh:
ps. more on topic: saw the preview for transformers (when i went and saw spiderman 3 - which i hated btw) and it looks wicked! ;)
I can't come anymore. Have works End-Of-Financial Year party that night :cool:
Never been to a drive in before..how does the sound come from our own car?? How does tht work??? Pretty keen! ANd whats all tht stuff bout bottoming out at the top??
Yeah sounds comes from your own car - you tune into a specific frequency and BANG - its works - its magic!
(as for bottoming out - just be careful thats all - because it is a drivein after all - ie hills everywhere)
I can't come anymore. Have works End-Of-Financial Year party that night :(
:D sounds from our car stereo... that mean the engine have to be running all the time ??? :D might need to bring a spare batt... :cool:
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
