Astra turbo is $36,990 retail for the coupe [obviously out of the price range].
an N/A R34 for $23k? I wouldnt like to see that, a half decent one will be out of your price range IMO too.
I think these 2 are good buys for the price "pug 206 GTI, Proton GTI" But if she is after a real *bang for buck* then a low vol import like a skyline or silvia really cant be beaten in the mid-size range.
Newsagents have buyers guides which would help decide on a locally made / delivered model car too.
An early model wrx is pretty good value and has 4 doors which a lot of women prefer [kids etc :spank:]...
Originally posted by predator666
that rex is good tho nark -- its in GC and pretty good for the price .. seen it once..
wasnt talkin about the rex :P
but i think i seen it at bennys not too long ago... the black wannabe carbon fibre look bonnet is a bit ricey.
a 92 model bmw 320 could be ok for that price.. insurance will be shit on any import.
proton satria gti and pug gti both good... the proton isnt sooo bad.. i had one until someone wrote it off.. a freind has one with 55,000kms on it and only serviced it twice and its still going strong.
are the BMW straight sixes really tunable??
i reckon WRX wagon's are cool... A bit of change to all the sedans around.
FTO sounds nice... but i have never driven any of the above mentioned cars except the BWM 320i (which was 94 i think) that was a beautiful car, torquey engine, strong brakes, real nice handling.
All well and good u driving these cars denham, but what did she think we she drove some of them? or u didn't let her? :)
320i - stock 110 kw I think... It's not too hard to get to about 140-150. If you want to go higher, supercharge or turbo-charge would be possible and give you up to 350+kw. :D
(Alternatively do what a friend of mine has done and dump a 4.0l NA v8 into one for 220rwkw. :D
Stock handling is fantastic, brakes are good, quality is good and you get to give Mrs INASNT a key with a BMW badge... :)
But then I'm biased...
Guest INASNT
bmw hey?
i some how dont see her in a bmw, i do myself in a M5 or 740 tho :D
SS8_Gohan
yes she did drive a few of the cars we looked at but she doesent ring their neck like i do in the test drive. The pug was the funniest, i did 7000rpm launches and 7000rpm changes while she did 2500rpm changes!! When u test drive a car u gotta give it a hrd time!
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
