Nah turn 2-4 are the scariest. Thanks to all involved and flaggies out in the wet.
Jarrod... You're a stirrer. You just wanted to see carnage! Best spot on the track for it though.
Shame about your engine Nick. Hope it gets sorted soon and cheap.
  • Replies 57
Posted Images
cheers to all who helped out... it was a tough day to be a flaggy! it took me a while to work out it was Jarrod at turn 4... kept wondering why this clown was giving me the blue flag when I had half the track to myself! haha
was a new experience going round there in the wet tho and it helped me improve when it dried out, I was a lot smoother...
so yeah I still haven't called my mechanic to find out his diagnosis, I'm too scared... but its probably safe to say I won't be on the track again this year:(
huge thanks to Chris for driving me home so far out of the way, and everyone who helped push the whale out of the pits! hehe
Yeah it was a bit cold ouy there Nick..
It was a sad moment to see your R33 leaving Sandown on the back of a Tow truck.
Hope its not to bad and your back on the road soon.. :)
no drama nick. bad luck mate...u were ripping them up until it died..
Kev, Debra, Phil & Brett,
Nice to see all of your familiar faces again. It was an awesome experience. I think I might have been bitten by the circuit bug thanks to my (I know you like this word Kev) "Virgin" run. :laughing-smiley-014:
A thousand thanks to all the instructors, flag marshalls (Brett and Phil how did you like the massive slide on turn one?), caterer (I really didn't think the food was gonna be so lavish! I was expecting mystery bags and bread!), fellow drivers and the strange and friendly parrot.
See you guys next round.
Track slippery? :kiss:
Cheers,
Lydz
OH NO Nick, sounds like you followed in my footsteps :kiss: What happened?
Hope it's nothing too serious and it doesn't cost you big $$$$'s to get it back on the road.
accelerating out from the 3rd last corner in 3rd gear, heard a clank, clank clank, pulled off into pits, called tow truck...
I reckon its a big end bearing (again aghh) but it could be a valve or something else, its up on the hoist today top see whether the noise is coming from the bottom end or head
I ignored the whole oil surge/bearing issue that plagues the GTR guys... but definately going to get the oil feed restrictors in there this time etc... goes to show you can still have problems running stock turbs and street tires
meh... rebuild thread coming soon;)
Track slippery? :thumbsup:
Cheers,
Lydz
lol u cracked me up. every time I looked in my rear view ur car was sideways..
Cheers,
Lydz
WOW.. 4 years since your last post..
Anyway i was on turn 1 when you had your first HEKTIC moment (flag n)
you were good to watch..
But you got the feel of it .. :)
But you got the feel of it .. :thumbsup:
Hehe... yeah.. it has been 4 years since i've had my R33 you know!
I'm an old-new member, i'm mostly in Nissan Silvia forum now anyways. Back then I was the rare girl driving an import so it was rather intimidating to socialise with the community.
Thanks, I guess a have an advantage in the wet as i'm not afriad to slide. I always try to be as interesting as possible (show pony!) :)
How close was I to hitting the wall on the last corner coming to the back straight?! I almost sh*t myself... almost. :D
Till next time fellas!
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
