  • Replies 56
HKS 3037S 56T, getting custom manifold, dump etc made up and getting it all ceramic coated - inlcuding the turbine housing. Just waiting to get it fitted - starting to itch..... I also have cams on order from Japan (being made) head gasket, exh cam gear, injectors, pump etc. The waiting is killing me!!!!
Anything in particular? The 550cc injectors there are very expensive for what they are, low impedance top feed and second hand - they are charging about the same price as side feed high impedance new from japan. Their lightened flywheels seem like a good buy at $295, but they weigh 6kg - second hand from Jap, I have seen 4.5kg flywheels for less.
Bottom line, sometimes places sell some stuff really cheap, other stuff not so cheap. I wouldnt say they are no good - just depends on what you are after.
to be honest is lag really shit to have on the street.
Whats 500 rmp in the context of going for that extra power.
when boost does hit its gonna be a heap of
fun.http://www.rotorworx.com.au/perfor_turbo.html
heres a link i just found, with a few other turbos you might not have looked at.
seem reasonably priced too for what they are capable of.
i was speaking to another guy on the forums. also has an rb25det in a solvia. and he was running one of the series 5 turbos.
he used the stndard manifold but just got two of the exhaust studs relocated. it cost him $20 to get done.
The car ran 13.8 on 8 psi at 106mph so cant be doing to bad.
just another way instead of spending mega dollars.
the turbos go for around $200 and then you could get it rebuild and hiflowed for around $800.
wouldn'd be a bad idea for the price.
i think he said it spooled up at 4000 rpm.
Rob, HKS 2835, or a garrett gt30, just make sure you get one with a smallish turbine AR ratio:) Either of those should be fine. If you have a talk to the guys Per4manz, or SST - I'm sure they would be able to find the perfect turbo. Your aims for rwhp v's lag seem pretty realistic, depends on how much you want to spend at the end of the day.:rolleyes:
INASNT, Evan (PSI fabrication) is making it.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
