Hey has anyone heard of a dent doctor that works out of his station wagon. I've got two little dents on my boot that looks like someone has either punched or kicked. just looking to get it fixed and wondering if anyone has heard of him?
Just after a contact number and a rough estimate of what it costs to get little dents fixed.
thanks guys
https://www.sau.com.au/forums/topic/169255-dents/
thanks guys
i dont know there number but if you did a search for them in the old phone book or on yellow pages.com.au under something like panel repairs or panel beaters.I used a guy called dent force and they came out to your car.They were approx $150 for a complete panel .Im on the sunshine coast but there will be someone in brissy for sure.Hope this helps
https://www.sau.com.au/forums/topic/169255-dents/#findComment-3128936
there was i guy that used to do bryan byrt fords dents called jason and he worked out of a magna wagon. he was awesome and a really nice bloke.
ring bill at bryan byrt ford upper mt gravatt and see if he'll give you his number
https://www.sau.com.au/forums/topic/169255-dents/#findComment-3129112
Does it have to be a dent doctor who uses a station wagon???
The only ones ive seen use Hiace van's like Lube Mobile...
Just under "Dent Doctor" in the whitepages...
They is another also called "Paintless dent removal" in the white pages...
Nah it doesnt have to be just was curious to see if anyone knew who I was referring to. Thanks for the tips Col I will give one of them a call.
Edited by smurf80
https://www.sau.com.au/forums/topic/169255-dents/#findComment-3135042
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
