ive been playing on a US server. I think West.
I tend to agree with higher level 1v1 games, I doubt they have to worry about shit tactics like cannon rushes.
This guy i played the other night, ran a drone down to my base and built a gateway, forge at my entrance, blocked me in with a couple cannons behind then came over the top with voids. I had no answer to it. Really pissed me off.
Been trying to expand faster (by 2min) doesnt work all the time, but it makes a massive difference with speed.
  • Replies 42
also got a keyboard that has a in built macro/key binding software for the extra keys.
I wrote some macros to select hatcheries, lava and then build whatever unit i want. That has also made me that little bit faster and easier to manage troops.
lol ye you will get idiots who do that type of thing in lower leagues/classes unfortunately.
You need to learn to use overlords to scout in that instance. Get early Lair and upgrade overlord speed = easy scouting.
Plus if he made cannons behind a gate/forge, you just make queens or roaches to push past it and then run in an dominate him.
Or use my fav weapon... Nydus Tunnels - to get your troops into his base easily.
Thats the thing with RTS - there is always a counter, you just have to know what it is and the only way is via experience and in-game scouting.
The best counter to voids early is just to make queens cause they can heal each other easily and do good dmg/range. Not too many towers as they cost minerals/drones so queens offer much better value. Hence I have usually 2 queens at each hatch to heal and defend easily as you can also heal towers with queens ;)
Once economy up and running i also make a 2nd hatch @ my main base and then have 3 queens so you can have 10-20 larve ready at any given time if you are waiting for tech or need to change units fast.
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
