Hey guys!
Currently setting up my new project.
Im on the hunt for 500kw on the rears.
Interested in knowing the following
- cams? 256?264?272?
- Turbo? 3540? T04z? Gt42?
- How Much boost?
- Injector Size? 750?850?1000cc?
Is there anyone on the forum that has 400/ 500 kw setup in their car.
Curious to know how much work is required plus the components needed.
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/
R32 GTR
Apexi PFC D-Jetro
Garrett t04Z turbo running 24psi
Apexi 53mm External Gate
Sard 700cc injectors
HKS Fuel Rail
HKS Fuel Reg
HKS Step II cams 272 272 10.2mm lift ,
HKS Valve Springs ,
HKS Valve Guides.
HKS adjustable cam wheels
Jun Oil Pump
Arias pistons with n1 rings
Pauter Conrods
608rwhp or 454 rwkw's at 24psi on Ultimate 98
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133635
As per the graph, max power is 578 hp at the rear wheels. This is an improvement of 37 hp on the same dyno by fitting a 272IN cam (previous 264) and spending dyno time optimising cam timing.
Setup is:
N1 block
HKS 2.8L crank
Nismo bearings
Pauter rods
ATI crank damper
HKS nickel coated pistons
GT-RS low mounts at 25 psi
HKS bridged manifold
HKS hard piping induction kit
Apexi 136mm IC
Greddy plenum
HKS fuel rail (twin entry, single return)
HKS fuel regulator
HKS 680 injectors
Nismo intank fuel pump (direct power feed)
HKS step 2 cams (272IN, 272EX)
HKS guides, springs and retainers
HKS timing belt
HKS cam gears
HKS metal head gasket
Ported head
Trust oil pump
N1 water pump
HKS dumps, pipes and exhaust
PFC D-Jetro
Blitz dual solenoid BC
Splitfire coils
HKS Twin Power CDI
HKS twin plate clutch
GTS4 diff centres front and rear (shorter ratio than GT-R)
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133643
just picked up my new GTR
1992 GTR
1000cc injectors
3X bosch fuel pumps
Standard plenum
re-ground standard cams
ARP rods
unknown pistons
T51R SPL BB turbo
AP racing Triple place clutch
Autronic computer X2
re built standard gearbox
AFR btween 12 and 13
last dyno:
631.3 ft/lb torque
578 kw at all 4
775.2 hp at all 4
that was running 2bar
dyno sheets to follow when i get scanner working
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133647
Setup is:
N1 block
HKS 2.8L crank
Nismo bearings
Pauter rods
ATI crank damper
Apexi 136mm IC
Greddy plenum
HKS fuel regulator
HKS 680 injectors
HKS timing belt
HKS cam gears
Ported head
Trust oil pump
N1 water pump
PFC D-Jetro
Splitfire coils
HKS Twin Power CDI
I just made that same power with GT-RS turbo's on 21 psi with pump fuel and a light tune.
a few differences though Nissan crank, bigger cams, more headwork. but much the same. All big $$ brand name stuff, Jun Hypertune etc. It will see some more boost this week as well as some race fuel and increased timing figures.
but budget at least $25000-$30000
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133679
1990 R32 GTR
Split fire coils
HKS 264/8.9 cams
OS Giken cam gears (not tuned)
Sard 850cc inj
Bosch 044 intank
stock internals/cooler etc
Jasma cat(less) back
HKS T45 S Spl turbine kit (cast manifold 50mm ext gate 4" dump, screamer)
RB20 afms
Apexi pods
Apexi Power FC
411.1 rwhp@ .7 bar
Rebuilt engine results soon..
Ceramic coated .5mm o/s CP forgies
Teflon coated skirts
Eagle Rods
King bearings
N1 pumps
HEad tickled
Port matched manifolds
Apexi 270/8.9 cams
Nismo head gasket 1.2mm
Blue printed/balanced crank (9000rpm)
Jun collar
Z32 afms
Ceramic coated exh manifolds/turbo/wastegate
Greddy Eo-1 ebc
Billet fuel rail
Sard fpr
Tomie sump baffle kit
Mines rocker cover baffle kit
Trust R intercooler
Apexi hard pipe kit
Aiming around 6-650 rwhp @1.5-1.8bar
Has already run 12.1@120mph before rebuild
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133681
Once the new 1000cc injectors arrive
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133748
ive got 2.7 jun stroker, 270 in/exh 10.8 cams hks t04z denso 1000cc injectors all the other bullshit along with it, hoping for around 450kw plus gas :)
after a year of building should be done next few weeks :D
Edited by 747.GTR
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3134119
Arrive at good reputation workshop with 1 x GTR R32, R33, R34 who cares.........
Open cheque book and say " how much for 500kw at the rear wheels?"
Expect to write a cheque for at least $30,000.00
Arrive 2 to 3 weeks later to pick up 500kw GTR
Drive off down the road smiling smuggly to yourself knowing that you will have one of the fastest cars to 50km/h on the planet. :thumbsup:
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3138544
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
