As it seems a few people from the club are going to the Queens Birthday track day organised by circuit club, I would try to make a list of who is going, so we can have an SAU presence there, maybe even head down in a group.
Details for the track day:HERE
I am booked in and am also trying to organise a garage so we have a spot to change wheels and store our stuff.
Please post here or PM if you are confirmed for this day and I will add you to the list.
For those who want to cruise down to Wakefield together, I can meet at Casula Bunnings car park at the cross roads from 6:30am leaving at 6:45am. This is located where the Hume Hwy splits into Camden Valley Way and Campbelltown Road. There is a link to a map on the second page.
I think this is a good spot as it is near the M7 and M5 and it is easy to get on the Freeway and head to Goulburn from this point.
Let me know who wants to meet up from here and PM me if you want my mobile to co ordinate things.
CONFIRMED:
Apollo (Me)
padey
tjandriesen aka "TJ"
scathing
Knockout Ned
https://www.sau.com.au/forums/topic/169631-circuit-club-wakefield-11062007/
  • Replies 92
Yeah I'll be there, along with a few mates.
Unfortunatly my car is only half sorted. I'm still waiting on my new front springs/other suspension bits to arrive and some cam gears and timing belt.
Knowing my luck, they wont arrive. But i'll have a stack of fun anyway.
wish i could make it, but too close to gold coast autosalon and that has sucked up all my money. I really wanted to get down there on some track rubber instead of the crap i used last time, mind you i still managed a 1:14 :thumbsup:
NEWS FLASH FOR THIS EVENT
I have just been informed that Circuit Club is having trouble arranging the timing equipment for this event. The usal company that does the timing is tied up with the V8 supercars.
So it may NOT be a timed track day!!!
I will still be going, I just hope they can arrange an alternative for timing.
Anymore SAU people coming as I need to let them know how many garages we need?
That means we are down to only 3 people from SAU for this event.
Is no one else up for a track day?
I'm a tenantative yes for this one
If I can get my power steering fixed in time I'll head down for a spin! But so far, it's not looking good.
What time do we need to be there?
I'll be taking the M2/M7/M5---->Goulburn.
ap
I'll check but I assume 8:30-9:00 - figure a 2 hour drive that mean we leave Sydney 6:30-7:00?
I'm just north of the bridge so I can either go across thur the city and catch the M5 by the airport or around and catch it M7 down.
I am now a maybe for this event.
Went for a wheel alignment on the weekend and found that something is bent in the rear as I have over 7 degrees of toe in on one of the rear tyres.
Hopefully can find the problem and repair before this day.
If I make it I will be happy to meet up somewhere and drive down as a group.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
